Обновил с версии 5.1.27 до 5.1.66 (позже до 5.1.68)
Проблема со старыми системниками, видеокарты с драйвером VIA не работают (только VESA no widescreen)
вот кусок лога:
11-33-44-659[initrd] TFTP: download and unpack file 5.1.68\packages\fwt from 192.168.0.22.
11-33-44-659[initrd] TFTP: download and unpack file 5.1.68\packages\f from 192.168.0.22.
11-33-44-659[KERNEL] [ 4.399752] random: nonblocking pool is initialized
11-33-44-659[initrd] TFTP: download and unpack file 5.1.68\packages\graphic from 192.168.0.22.
11-33-44-659[gm] WTware session manager v.5.1.68.
11-33-44-659[gm] Add keyboard event5: 2.4G KB 2.4G Mouse.
11-33-44-659[gm] Add keyboard event4: 2.4G KB 2.4G Mouse.
11-33-44-659[gm] Ignore event3: PC Speaker.
11-33-44-659[gm] Add keyboard event2: Power Button.
11-33-44-659[gm] Add keyboard event1: Sleep Button.
11-33-44-659[gm] Add keyboard event0: Power Button.
11-33-44-659[gm] Display mode: 1366x768, 16 bit, 0 Hz, modeline "", DDC enabled, connector 0.
11-33-44-659[gm] modprobe drm.
11-33-44-659[KERNEL] [ 6.981142] Linux agpgart interface v0.103
11-33-44-659[KERNEL] [ 6.987386] [drm] Initialized drm 1.1.0 20060810
11-33-44-659[gm] Run modprobe via modeset=1.
11-33-44-659[gm] modprobe via modeset=1.
11-33-44-659[KERNEL] [ 7.018370] [TTM] Zone kernel: Available graphics memory: 95228 kiB
11-33-44-659[KERNEL] [ 7.018423] [TTM] Initializing pool allocator
11-33-44-659[KERNEL] [ 7.018645] [drm] Detected 64 MB of DDR 333 Video RAM at physical address 0xe8000000.
11-33-44-659[KERNEL] [ 7.018699] [drm] Detected MMIO at physical address 0xec000000.
11-33-44-659[KERNEL] [ 7.018736] [drm] Allocated 256 KB of memory for VQ
11-33-44-659[KERNEL] [ 7.019284] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
11-33-44-659[KERNEL] [ 7.019288] [drm] No driver support for vblank timestamp query.
11-33-44-659[KERNEL] [ 7.064576] [drm] Internal DVI not detected
11-33-44-659[KERNEL] [ 7.143281] BUG: unable to handle kernel NULL pointer dereference at 0000000d
11-33-44-659[KERNEL] [ 7.143293] IP: [<cc959c65>] via_fb_probe+0x175/0x2e0 [via]
11-33-44-659[KERNEL] [ 7.143324] *pde = 00000000
11-33-44-659[KERNEL] [ 7.143328] Oops: 0000 [#1] PREEMPT
11-33-44-659[KERNEL] [ 7.143332] Modules linked in: via(+) drm_kms_helper ttm i2c_algo_bit cfbfillrect cfbimgblt cfbcopyarea fb fbdev drm agpgart via_rhine mii
11-33-44-659[KERNEL] [ 7.143349] CPU: 0 PID: 449 Comm: modprobe Not tainted 3.13.11 #1
11-33-44-659[KERNEL] [ 7.143354] Hardware name: VIA Technologies, Inc. KM400-8237/KM400-8237, BIOS 6.00 PG 03/08/2005
11-33-44-659[KERNEL] [ 7.143357] task: cb516110 ti: c929e000 task.ti: c929e000
11-33-44-659[KERNEL] [ 7.143362] EIP: 0060:[<cc959c65>] EFLAGS: 00010246 CPU: 0
11-33-44-659[KERNEL] [ 7.143362] EIP is at via_fb_probe+0x175/0x2e0 [via]
11-33-44-659[KERNEL] [ 7.143362] EAX: c9442040 EBX: c9436e90 ECX: 00000000 EDX: 00000001
11-33-44-659[KERNEL] [ 7.143362] ESI: c929fc60 EDI: c9436c00 EBP: c9400000 ESP: c929fb90
11-33-44-659[KERNEL] [ 7.143362] DS: 007b ES: 007b FS: 0000 GS: 0033 SS: 0068
11-33-44-659[KERNEL] [ 7.143362] CR0: 8005003b CR2: 0000000d CR3: 08ac4000 CR4: 00000790
11-33-44-659[KERNEL] [ 7.143362] Stack:
11-33-44-659[KERNEL] [ 7.143362] 00000004 00000001 00001000 00000000 00000000 c9436f0c 00402000 cac7d680
11-33-44-659[KERNEL] [ 7.143362] c9436f00 00000001 00000000 cacec800 c8ac8e00 00000000 00000000 00000000
11-33-44-659[KERNEL] [ 7.143362] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
11-33-44-659[KERNEL] [ 7.143362] Call Trace:
11-33-44-659[KERNEL] [ 7.143362] [<cc91fec5>] ? drm_fb_helper_initial_config+0x2a5/0x490 [drm_kms_helper]
11-33-44-659[KERNEL] [ 7.143362] [<cc95af52>] ? via_framebuffer_init+0x122/0x160 [via]
11-33-44-659[KERNEL] [ 7.143362] [<cc95e073>] ? via_tmds_init+0x1f3/0x200 [via]
11-33-44-659[KERNEL] [ 7.143362] [<cc954969>] ? via_modeset_init+0x629/0xcf0 [via]
11-33-44-659[KERNEL] [ 7.143362] [<cc9513c1>] ? via_fence_pool_init+0x111/0x210 [via]
11-33-44-659[KERNEL] [ 7.143362] [<cc94b7f0>] ? via_driver_load+0x470/0x7f0 [via]
11-33-44-659[KERNEL] [ 7.143362] [<cc877653>] ? drm_dev_register+0x83/0x1a0 [drm]
11-33-44-659[KERNEL] [ 7.143362] [<cc878ea9>] ? drm_get_pci_dev+0x79/0x120 [drm]
11-33-44-659[KERNEL] [ 7.143362] [<c01e45e4>] ? sysfs_new_dirent+0x84/0x100
11-33-44-659[KERNEL] [ 7.143362] [<c022ca31>] ? pci_device_probe+0x51/0xa0
11-33-44-659[KERNEL] [ 7.143362] [<c0282e60>] ? __device_attach+0x40/0x40
11-33-44-659[KERNEL] [ 7.143362] [<c01e52ad>] ? sysfs_create_link+0x1d/0x40
11-33-44-659[KERNEL] [ 7.143362] [<c0282ca2>] ? really_probe+0x42/0x1c0
11-33-44-659[KERNEL] [ 7.143362] [<c020fc88>] ? kobject_add_internal+0x178/0x2b0
11-33-44-659[KERNEL] [ 7.143362] [<c0282ed7>] ? __driver_attach+0x77/0x80
11-33-44-659[KERNEL] [ 7.143362] [<c028167f>] ? bus_for_each_dev+0x3f/0x70
11-33-44-659[KERNEL] [ 7.143362] [<c0282906>] ? driver_attach+0x16/0x20
11-33-44-659[KERNEL] [ 7.143362] [<c02825ff>] ? bus_add_driver+0x11f/0x1d0
11-33-44-659[KERNEL] [ 7.143362] [<c0283421>] ? driver_register+0x51/0xd0
11-33-44-659[KERNEL] [ 7.143362] [<cc967000>] ? 0xcc966fff
11-33-44-659[KERNEL] [ 7.143362] [<c010043a>] ? do_one_initcall+0xca/0x110
11-33-44-659[KERNEL] [ 7.143362] [<c016f272>] ? jump_label_module_notify+0x172/0x1c0
11-33-44-659[KERNEL] [ 7.143362] [<c0143406>] ? notifier_call_chain+0x46/0x60
11-33-44-659[KERNEL] [ 7.143362] [<c01436c0>] ? __blocking_notifier_call_chain+0x40/0x50
11-33-44-659[KERNEL] [ 7.143362] [<c0162e9b>] ? load_module+0x14eb/0x1cf0
11-33-44-659[KERNEL] [ 7.143362] [<c0123e50>] ? vmalloc_sync_all+0x100/0x100
11-33-44-659[KERNEL] [ 7.143362] [<c016370b>] ? SyS_init_module+0x6b/0xa0
11-33-44-659[KERNEL] [ 7.143362] [<c039020a>] ? sysenter_do_call+0x12/0x26
11-33-44-659[KERNEL] [ 7.143362] Code: 24 08 00 10 00 00 c7 44 24 04 01 00 00 00 c7 04 24 04 00 00 00 e8 fc 61 ff ff 85 c0 89 c1 0f 85 47 ff ff ff 8b 54 24 24 8b 43 7c <8b> 52 0c 89 50 58 8b 54 24 20 8b 43 7c e8 b9 62 ff ff 85 c0 89
11-33-44-659[KERNEL] [ 7.143362] EIP: [<cc959c65>] via_fb_probe+0x175/0x2e0 [via] SS:ESP 0068:c929fb90
11-33-44-659[KERNEL] [ 7.143362] CR2: 000000000000000d
11-33-44-659[KERNEL] [ 7.144313] ---[ end trace 431b5926b526f0fe ]---
11-33-44-659[gm] hardwareConfiguration.cpp ( 28), modprobe: -- ERROR -- INTERNAL ERROR. Please, contact WTware tech support.
11-33-44-659[pfac] Process pid 426 terminated, status 00000000.
Драйвер VIA в 5.1.66(68)
Re: Драйвер VIA в 5.1.66(68)
Пичалька
Драйвер VIA в ядро не пускают: кривой. Раньше находились люди, которые поддерживали его в близком к ядру состоянии. Сейчас похоже все забили на VIA. Проще оставить эти машинки на старых версиях втвари, где работало.
