Загрузка wtware + mikrotik
Ares
Сообщение Ares »
Настроили загрузку wtware с mikrotik (на нем dhcp + tftp).
Загрузка проходит и все работает, но в логах имеет ошибка, хотелось бы устранить.
08:59:41 dhcp,info dhcp1 assigned 192.168.112.21 to 7C:05:07:B4:E3:9F
08:59:41 tftp,debug tftpd incoming connection from 192.168.112.21:2070 on 192.168.112.1
08:59:41 tftp,debug requested file(binary): disk1/wtware/5.2.32/wtware.pxe\00 access: allowed
08:59:41 tftp,debug opened 192.168.112.1:41633
08:59:41 tftp,error ERROR: code 0
08:59:41 tftp,debug closing connection to 192.168.112.21:2070
08:59:41 tftp,debug tftpd incoming connection from 192.168.112.21:2071 on 192.168.112.1
08:59:41 tftp,debug opened 192.168.112.1:44427
08:59:41 tftp,debug tftpd incoming connection from 192.168.112.21:57089 on 192.168.112.1
08:59:41 tftp,debug requested file(binary): disk1/wtware/5.2.32/a0597062-b9cc-e211-bfb1-7c0507b4e39f\00 access: allowed
08:59:41 tftp,debug opened 192.168.112.1:56851
08:59:41 tftp,error ERROR code:1 string:file not found
08:59:41 tftp,debug tftpd incoming connection from 192.168.112.21:57090 on 192.168.112.1
08:59:41 tftp,debug requested file(binary): disk1/wtware/5.2.32/01-7c-05-07-b4-e3-9f\00 access: allowed
08:59:41 tftp,debug opened 192.168.112.1:52635
08:59:41 tftp,debug tftpd incoming connection from 192.168.112.21:57091 on 192.168.112.1
08:59:41 tftp,debug requested file(binary): disk1/wtware/5.2.32/C0A87015\00 access: allowed
08:59:41 tftp,debug opened 192.168.112.1:55502
08:59:41 tftp,debug tftpd incoming connection from 192.168.112.21:57092 on 192.168.112.1
08:59:41 tftp,debug requested file(binary): disk1/wtware/5.2.32/C0A8701\00 access: allowed
08:59:41 tftp,debug opened 192.168.112.1:41306
08:59:41 tftp,debug tftpd incoming connection from 192.168.112.21:57093 on 192.168.112.1
08:59:41 tftp,debug requested file(binary): disk1/wtware/5.2.32/C0A870\00 access: allowed
08:59:41 tftp,debug opened 192.168.112.1:57229
08:59:41 tftp,debug tftpd incoming connection from 192.168.112.21:57094 on 192.168.112.1
08:59:41 tftp,debug requested file(binary): disk1/wtware/5.2.32/C0A87\00 access: allowed
08:59:41 tftp,debug opened 192.168.112.1:49532
08:59:41 tftp,debug tftpd incoming connection from 192.168.112.21:57095 on 192.168.112.1
08:59:41 tftp,debug requested file(binary): disk1/wtware/5.2.32/C0A8\00 access: allowed
08:59:41 tftp,debug opened 192.168.112.1:47746
08:59:41 tftp,debug tftpd incoming connection from 192.168.112.21:57096 on 192.168.112.1
08:59:41 tftp,debug requested file(binary): disk1/wtware/5.2.32/C0A\00 access: allowed
08:59:41 tftp,debug opened 192.168.112.1:47267
08:59:41 tftp,debug tftpd incoming connection from 192.168.112.21:57097 on 192.168.112.1
08:59:41 tftp,debug requested file(binary): disk1/wtware/5.2.32/C0\00 access: allowed
08:59:41 tftp,debug opened 192.168.112.1:52161
08:59:41 tftp,debug tftpd incoming connection from 192.168.112.21:57098 on 192.168.112.1
08:59:41 tftp,debug requested file(binary): disk1/wtware/5.2.32/C\00 access: allowed
08:59:41 tftp,debug opened 192.168.112.1:38102
08:59:41 tftp,debug tftpd incoming connection from 192.168.112.21:57099 on 192.168.112.1
08:59:41 tftp,debug requested file(binary): disk1/wtware/5.2.32/pxe.cfg\00 access: allowed
08:59:41 tftp,debug opened 192.168.112.1:46308
08:59:41 tftp,debug tftpd incoming connection from 192.168.112.21:57100 on 192.168.112.1
08:59:41 tftp,debug requested file(binary): disk1/wtware/5.2.32/packages/kernel\00 access: allowed
08:59:41 tftp,debug opened 192.168.112.1:48494
08:59:42 tftp,debug tftpd incoming connection from 192.168.112.21:57101 on 192.168.112.1
08:59:42 tftp,debug requested file(binary): disk1/wtware/5.2.32/packages/initrd\00 access: allowed
08:59:42 tftp,debug opened 192.168.112.1:39859
08:59:49 dhcp,info dhcp1 deassigned 192.168.112.21 from 7C:05:07:B4:E3:9F
08:59:50 dhcp,info dhcp1 assigned 192.168.112.21 to 7C:05:07:B4:E3:9F
08:59:51 tftp,debug tftpd incoming connection from 192.168.112.21:60561 on 192.168.112.1
08:59:51 tftp,debug requested file(binary): WTware v.5.2.32 at 7C:05:07:B4:E3:9F, dhcp=192.168.112.1.\00 access: allowed
08:59:51 tftp,debug opened 192.168.112.1:41729
08:59:51 tftp,error ERROR code:1 string:file not found
08:59:51 tftp,debug tftpd incoming connection from 192.168.112.21:59782 on 192.168.112.1
08:59:51 tftp,debug requested file(binary): disk1/wtware/5.2.32/packages/lib6\00 access: allowed
08:59:51 tftp,debug opened 192.168.112.1:34162
08:59:52 tftp,debug tftpd incoming connection from 192.168.112.21:59973 on 192.168.112.1
08:59:52 tftp,debug requested file(binary): disk1/wtware/Everyone/list.wtc\00 access: allowed
08:59:52 tftp,debug opened 192.168.112.1:33402
08:59:52 tftp,debug tftpd incoming connection from 192.168.112.21:36330 on 192.168.112.1
08:59:52 tftp,debug requested file(binary): disk1/wtware/ListIncludes/ts.wtc\00 access: allowed
08:59:52 tftp,debug opened 192.168.112.1:45478
08:59:52 tftp,debug tftpd incoming connection from 192.168.112.21:60914 on 192.168.112.1
08:59:52 tftp,debug requested file(binary): disk1/wtware/Terminals/7C.05.07.B4.E3.9F/config.wtc\00 access: allowed
08:59:52 tftp,debug opened 192.168.112.1:54127
08:59:52 tftp,debug tftpd incoming connection from 192.168.112.21:37686 on 192.168.112.1
08:59:52 tftp,debug requested file(binary): disk1/wtware/Everyone/all.wtc\00 access: allowed
08:59:52 tftp,debug opened 192.168.112.1:47796
08:59:52 tftp,debug tftpd incoming connection from 192.168.112.21:51558 on 192.168.112.1
08:59:52 tftp,debug requested file(binary): disk1/wtware/Everyone/wtware.lic\00 access: allowed
08:59:52 tftp,debug opened 192.168.112.1:52423
08:59:52 tftp,debug tftpd incoming connection from 192.168.112.21:46140 on 192.168.112.1
08:59:52 tftp,debug requested file(binary): disk1/wtware/5.2.32/packages/f\00 access: allowed
08:59:52 tftp,debug opened 192.168.112.1:55138
08:59:55 tftp,debug tftpd incoming connection from 192.168.112.21:49281 on 192.168.112.1
08:59:55 tftp,debug requested file(binary): disk1/wtware/5.2.32/packages/fwt6\00 access: allowed
08:59:55 tftp,debug opened 192.168.112.1:48309
08:59:55 tftp,debug tftpd incoming connection from 192.168.112.21:56470 on 192.168.112.1
08:59:55 tftp,debug requested file(binary): disk1/wtware/5.2.32/packages/graphic\00 access: allowed
08:59:55 tftp,debug opened 192.168.112.1:57061
08:59:56 tftp,debug connection timeout
08:59:58 tftp,debug tftpd incoming connection from 192.168.112.21:44277 on 192.168.112.1
08:59:58 tftp,debug requested file(binary): WTware v.5.2.32 at 7C:05:07:B4:E3:9F[ARG-WTware_21], dhcp=192.168.112.1.\00 access: allow
ed
08:59:58 tftp,debug opened 192.168.112.1:55773
08:59:58 tftp,error ERROR code:1 string:file not found
08:59:58 tftp,debug tftpd incoming connection from 192.168.112.21:33326 on 192.168.112.1
08:59:58 tftp,debug requested file(binary): disk1/wtware/Graphic/sample/wait.png\00 access: allowed
08:59:58 tftp,debug opened 192.168.112.1:36263
09:00:06 tftp,debug connection timeout
09:00:07 tftp,debug tftpd incoming connection from 192.168.112.21:47502 on 192.168.112.1
09:00:07 tftp,debug requested file(binary): disk1/wtware/Graphic/sample/popup.png\00 access: allowed
09:00:07 tftp,debug opened 192.168.112.1:47653
09:00:07 tftp,debug tftpd incoming connection from 192.168.112.21:36341 on 192.168.112.1
09:00:07 tftp,debug requested file(binary): disk1/wtware/5.2.32/packages/fs\00 access: allowed
09:00:07 tftp,debug opened 192.168.112.1:38880
09:00:16 tftp,debug connection timeout
09:00:26 tftp,debug connection timeout
Re: Загрузка wtware + mikrotik
Что из этого ошибка? По-моему, нормально всё.
Начинает искать C0A87015
затем уменьшает на один символ и так до
и после этого обращается
Вот это и смутило. Вы считаете, что это нормально?
Так ведёт себя загрузчик pxelinux, который втварь использяет для загрузки по сети на x86. Умные дядьки, которые его делали, считали несколько лишних запросов разумной платой за дополнительную гибкость. Этот механизм может понадобиться, если какому-то одному терминалу для запуска нужно будет каой-нибудь специальный костыль в командной строке ядра указать. Задача очень редкая, но и цена пустяковая, несколько лишних TFTP запросов, милисекунды времени и меньше килобайта трафика.
