VeriFone VX 520
Добавлено: Ср ноя 15, 2017 3:12 pm
Не получается подключиться к терминалу VeriFone VX 520 через USB эмуляцию com порта.
в конфиг добавляю serial=COM4(usb) , change port выдает:
но подключиться к этому терминалу через com4 не могу.
Если подключаю все это дело в windows и подключаюсь к тому же RDP серверу через mstsc - то все работает.
Вот мой лог
AUX = \DosDevices\COM1
COM1 = \Device\Serial0
COM2 = \Device\Serial1
COM4 = \Device\RdpDrPort\;COM4:5\tsclient\COM4
Вот мой лог
WTware v.5.4.52 supervisor.
WTC listener is active.
[ KERNEL] [ 0.000000] Linux version 4.4.23 (root@c12) (gcc version 5.4.0 20160609 (Ubuntu 5.4.0-6ubuntu1~16.04.2) ) #1 SMP Sat Oct 1 02:32:02 SAMT 2016
[ KERNEL] [ 0.000000] KERNEL supported cpus:
[ KERNEL] [ 0.000000] Intel GenuineIntel
[ KERNEL] [ 0.000000] AMD AuthenticAMD
[ KERNEL] [ 0.000000] x86/fpu: Legacy x87 FPU detected.
[ KERNEL] [ 0.000000] x86/fpu: Using 'lazy' FPU context switches.
[ KERNEL] [ 0.000000] e820: BIOS-provided physical RAM map:
[ KERNEL] [ 0.000000] BIOS-e820: [mem 0x0000000000000000-0x000000000009e7ff] usable
[ KERNEL] [ 0.000000] BIOS-e820: [mem 0x000000000009e800-0x000000000009ffff] reserved
[ KERNEL] [ 0.000000] BIOS-e820: [mem 0x00000000000f0000-0x00000000000fffff] reserved
[ KERNEL] [ 0.000000] BIOS-e820: [mem 0x0000000000100000-0x000000001efaffff] usable
[ KERNEL] [ 0.000000] BIOS-e820: [mem 0x000000001efb0000-0x000000001efb2fff] ACPI NVS
[ KERNEL] [ 0.000000] BIOS-e820: [mem 0x000000001efb3000-0x000000001efbffff] ACPI data
[ KERNEL] [ 0.000000] BIOS-e820: [mem 0x00000000ffff0000-0x00000000ffffffff] reserved
[ KERNEL] [ 0.000000] Notice: NX (Execute Disable) protection missing in CPU!
[ KERNEL] [ 0.000000] SMBIOS 2.2 present.
[ KERNEL] [ 0.000000] DMI: /AMD-GX3, BIOS 6.00 PG 04/22/2008
[ KERNEL] [ 0.000000] e820: update [mem 0x00000000-0x00000fff] usable ==> reserved
[ KERNEL] [ 0.000000] e820: remove [mem 0x000a0000-0x000fffff] usable
[ KERNEL] [ 0.000000] e820: last_pfn = 0x1efb0 max_arch_pfn = 0x100000
[ KERNEL] [ 0.000000] MTRR: Disabled
[ KERNEL] [ 0.000000] x86/PAT: MTRRs disabled, skipping PAT initialization too.
[ KERNEL] [ 0.000000] x86/PAT: Configuration [0-7]: WB WT UC- UC WB WT UC- UC
[ KERNEL] [ 0.000000] initial memory mapped: [mem 0x00000000-0x017fffff]
[ KERNEL] [ 0.000000] Base memory trampoline at [c0099000] 99000 size 16384
[ KERNEL] [ 0.000000] BRK [0x01599000, 0x01599fff] PGTABLE
[ KERNEL] [ 0.000000] early_memtest: # of tests: 1
[ KERNEL] [ 0.000000] 0x00010000 - 0x00099000 pattern 0000000000000000
[ KERNEL] [ 0.000000] 0x0009d000 - 0x0009d800 pattern 0000000000000000
[ KERNEL] [ 0.000000] 0x00100000 - 0x01000000 pattern 0000000000000000
[ KERNEL] [ 0.000000] 0x0159f000 - 0x1ec42000 pattern 0000000000000000
[ KERNEL] [ 0.000000] 0x1ef8f000 - 0x1efb0000 pattern 0000000000000000
[ KERNEL] [ 0.000000] RAMDISK: [mem 0x1ec42000-0x1ef8efff]
[ KERNEL] [ 0.000000] ACPI: Early table checksum verification disabled
[ KERNEL] [ 0.000000] ACPI: RSDP 0x00000000000F60D0 000014 (v00 AMDGX3)
[ KERNEL] [ 0.000000] ACPI: RSDT 0x000000001EFB3000 000028 (v01 AMDGX3 AWRDACPI 42302E31 AWRD 00000000)
[ KERNEL] [ 0.000000] ACPI: FACP 0x000000001EFB3080 000074 (v01 AMDGX3 AWRDACPI 42302E31 AWRD 00000000)
[ KERNEL] [ 0.000000] ACPI BIOS Warning (bug): Invalid length for FADT/Pm2ControlBlock: 16, using default 8 (20150930/tbfadt-704)
[ KERNEL] [ 0.000000] ACPI: DSDT 0x000000001EFB3100 002CBD (v01 AMDGX3 AWRDACPI 00001000 MSFT 03000000)
[ KERNEL] [ 0.000000] ACPI: FACS 0x000000001EFB0000 000040
[ KERNEL] [ 0.000000] 0MB HIGHMEM available.
[ KERNEL] [ 0.000000] 495MB LOWMEM available.
[ KERNEL] [ 0.000000] mapped low ram: 0 - 1efb0000
[ KERNEL] [ 0.000000] low ram: 0 - 1efb0000
[ KERNEL] [ 0.000000] BRK [0x0159a000, 0x0159afff] PGTABLE
[ KERNEL] [ 0.000000] Zone ranges:
[ KERNEL] [ 0.000000] DMA [mem 0x0000000000001000-0x0000000000ffffff]
[ KERNEL] [ 0.000000] Normal [mem 0x0000000001000000-0x000000001efaffff]
[ KERNEL] [ 0.000000] HighMem empty
[ KERNEL] [ 0.000000] Movable zone start for each node
[ KERNEL] [ 0.000000] Early memory node ranges
[ KERNEL] [ 0.000000] node 0: [mem 0x0000000000001000-0x000000000009dfff]
[ KERNEL] [ 0.000000] node 0: [mem 0x0000000000100000-0x000000001efaffff]
[ KERNEL] [ 0.000000] Initmem setup node 0 [mem 0x0000000000001000-0x000000001efaffff]
[ KERNEL] [ 0.000000] On node 0 totalpages: 126797
[ KERNEL] [ 0.000000] free_area_init_node: node 0, pgdat c14de6c0, node_mem_map de862020
[ KERNEL] [ 0.000000] DMA zone: 32 pages used for memmap
[ KERNEL] [ 0.000000] DMA zone: 0 pages reserved
[ KERNEL] [ 0.000000] DMA zone: 3997 pages, LIFO batch:0
[ KERNEL] [ 0.000000] Normal zone: 960 pages used for memmap
[ KERNEL] [ 0.000000] Normal zone: 122800 pages, LIFO batch:31
[ KERNEL] [ 0.000000] Using APIC driver default
[ KERNEL] [ 0.000000] ACPI: PM-Timer IO Port: 0x9c10
[ KERNEL] [ 0.000000] smpboot: Allowing 1 CPUs, 0 hotplug CPUs
[ KERNEL] [ 0.000000] No local APIC present or hardware disabled
[ KERNEL] [ 0.000000] APIC: disable apic facility
[ KERNEL] [ 0.000000] APIC: switched to apic NOOP
[ KERNEL] [ 0.000000] e820: [mem 0x1efc0000-0xfffeffff] available for PCI devices
[ KERNEL] [ 0.000000] clocksource: refined-jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645519600211568 ns
[ KERNEL] [ 0.000000] setup_percpu: NR_CPUS:8 nr_cpumask_bits:8 nr_cpu_ids:1 nr_node_ids:1
[ KERNEL] [ 0.000000] PERCPU: Embedded 16 pages/cpu @def9c000 s33484 r0 d32052 u65536
[ KERNEL] [ 0.000000] pcpu-alloc: s33484 r0 d32052 u65536 alloc=16*4096
[ KERNEL] [ 0.000000] pcpu-alloc: [0] 0
[ KERNEL] [ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 125805
[ KERNEL] [ 0.000000] Kernel command line: root=/dev/ram0 quiet initrd=packages/initrd BOOT_IMAGE=packages/kernel
[ KERNEL] [ 0.000000] PID hash table entries: 2048 (order: 1, 8192 bytes)
[ KERNEL] [ 0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
[ KERNEL] [ 0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
[ KERNEL] [ 0.000000] Initializing CPU#0
[ KERNEL] [ 0.000000] Initializing HighMem for node 0 (00000000:00000000)
[ KERNEL] [ 0.000000] Memory: 493540K/507188K available (3791K kernel code, 205K rwdata, 1004K rodata, 380K init, 292K bss, 13648K reserved, 0K cma-reserved, 0K highmem)
[ KERNEL] [ 0.000000] virtual kernel memory layout:
[ KERNEL] [ 0.000000] fixmap : 0xfff17000 - 0xfffff000 ( 928 kB)
[ KERNEL] [ 0.000000] pkmap : 0xff800000 - 0xffc00000 (4096 kB)
[ KERNEL] [ 0.000000] vmalloc : 0xdf7b0000 - 0xff7fe000 ( 512 MB)
[ KERNEL] [ 0.000000] lowmem : 0xc0000000 - 0xdefb0000 ( 495 MB)
[ KERNEL] [ 0.000000] .init : 0xc14e6000 - 0xc1545000 ( 380 kB)
[ KERNEL] [ 0.000000] .data : 0xc13b3f3c - 0xc14e4600 (1217 kB)
[ KERNEL] [ 0.000000] .text : 0xc1000000 - 0xc13b3f3c (3791 kB)
[ KERNEL] [ 0.000000] Checking if this processor honours the WP bit even in supervisor mode...Ok.
[ KERNEL] [ 0.000000] SLUB: HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
[ KERNEL] [ 0.000000] RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=1.
[ KERNEL] [ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=32, nr_cpu_ids=1
[ KERNEL] [ 0.000000] NR_IRQS:2304 nr_irqs:32 16
[ KERNEL] [ 0.000000] CPU 0 irqstacks, hard=de408000 soft=de40a000
[ KERNEL] [ 0.000000] Console: colour VGA+ 80x25
[ KERNEL] [ 0.000000] console [tty0] enabled
[ KERNEL] [ 0.000000] tsc: Fast TSC calibration using PIT
[ KERNEL] [ 0.000000] tsc: Detected 498.676 MHz processor
[ KERNEL] [ 0.008024] Calibrating delay loop (skipped), value calculated using timer frequency.. 997.35 BogoMIPS (lpj=1994704)
[ KERNEL] [ 0.008043] pid_max: default: 32768 minimum: 301
[ KERNEL] [ 0.008075] ACPI: Core revision 20150930
[ KERNEL] [ 0.025252] ACPI: 1 ACPI AML tables successfully acquired and loaded
[ KERNEL] [ 0.025279] ACPI: setting ELCR to 0200 (from 0c20)
[ KERNEL] [ 0.025389] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ KERNEL] [ 0.025405] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ KERNEL] [ 0.026197] Last level iTLB entries: 4KB 0, 2MB 0, 4MB 0
[ KERNEL] [ 0.026212] Last level dTLB entries: 4KB 0, 2MB 0, 4MB 0, 1GB 0
[ KERNEL] [ 0.033424] Freeing SMP alternatives memory: 16K (c1545000 - c1549000)
[ KERNEL] [ 0.036349] smpboot: weird, boot CPU (#0) not listed by the BIOS
[ KERNEL] [ 0.036362] smpboot: SMP motherboard not detected
[ KERNEL] [ 0.036371] smpboot: SMP disabled
[ KERNEL] [ 0.036383] smpboot: Local APIC not detected. Using dummy APIC emulation.
[ KERNEL] [ 0.036454] Performance Events: no PMU driver, software events only.
[ KERNEL] [ 0.037624] x86: Booted up 1 node, 1 CPUs
[ KERNEL] [ 0.037642] smpboot: Total of 1 processors activated (997.35 BogoMIPS)
[ KERNEL] [ 0.040430] devtmpfs: initialized
[ KERNEL] [ 0.041994] PM: Registering ACPI NVS region [mem 0x1efb0000-0x1efb2fff] (12288 bytes)
[ KERNEL] [ 0.042386] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ KERNEL] [ 0.043569] NET: Registered protocol family 16
[ KERNEL] [ 0.044629] cpuidle: using governor ladder
[ KERNEL] [ 0.044652] cpuidle: using governor menu
[ KERNEL] [ 0.044880] clocksource: pit: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1601818034827 ns
[ KERNEL] [ 0.044949] ACPI: bus type PCI registered
[ KERNEL] [ 0.049660] PCI: PCI BIOS revision 2.10 entry at 0xfaad0, last bus=0
[ KERNEL] [ 0.049673] PCI: Using configuration type 1 for base access
[ KERNEL] [ 0.071103] ACPI: Added _OSI(Module Device)
[ KERNEL] [ 0.071123] ACPI: Added _OSI(Processor Device)
[ KERNEL] [ 0.071137] ACPI: Added _OSI(3.0 _SCP Extensions)
[ KERNEL] [ 0.071151] ACPI: Added _OSI(Processor Aggregator Device)
[ KERNEL] [ 0.089696] ACPI: Interpreter enabled
[ KERNEL] [ 0.089760] ACPI Exception: AE_NOT_FOUND, While evaluating Sleep State [\_S2_] (20150930/hwxface-580)
[ KERNEL] [ 0.089832] ACPI: (supports S0 S1 S3 S5)
[ KERNEL] [ 0.089845] ACPI: Using PIC for interrupt routing
[ KERNEL] [ 0.090076] PCI: Using host bridge windows from ACPI; if necessary, use "pci=nocrs" and report a bug
[ KERNEL] [ 0.124568] ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-ff])
[ KERNEL] [ 0.124608] acpi PNP0A03:00: _OSC: OS supports [ASPM ClockPM Segments]
[ KERNEL] [ 0.124644] acpi PNP0A03:00: _OSC failed (AE_NOT_FOUND); disabling ASPM
[ KERNEL] [ 0.124672] acpi PNP0A03:00: fail to add MMCONFIG information, can't access extended PCI configuration space under this bridge.
[ KERNEL] [ 0.125451] PCI host bridge to bus 0000:00
[ KERNEL] [ 0.125478] pci_bus 0000:00: root bus resource [io 0x0000-0x0cf7 window]
[ KERNEL] [ 0.125499] pci_bus 0000:00: root bus resource [io 0x0d00-0xac17 window]
[ KERNEL] [ 0.125520] pci_bus 0000:00: root bus resource [io 0xac20-0xffff window]
[ KERNEL] [ 0.125541] pci_bus 0000:00: root bus resource [mem 0x000a0000-0x000bffff window]
[ KERNEL] [ 0.125563] pci_bus 0000:00: root bus resource [mem 0x000c8000-0x000dffff window]
[ KERNEL] [ 0.125584] pci_bus 0000:00: root bus resource [mem 0x1efc0000-0xfebfffff window]
[ KERNEL] [ 0.125605] pci_bus 0000:00: root bus resource [bus 00-ff]
[ KERNEL] [ 0.125760] pci 0000:00:01.0: [1022:2080] type 00 class 0x060000
[ KERNEL] [ 0.125962] pci 0000:00:01.0: reg 0x10: [io 0xac1c-0xac1f]
[ KERNEL] [ 0.126079] pci 0000:00:01.0: reg 0x14: [io 0x9e00-0x9e07]
[ KERNEL] [ 0.127517] pci 0000:00:01.1: [1022:2081] type 00 class 0x030000
[ KERNEL] [ 0.127880] pci 0000:00:01.1: reg 0x10: [mem 0xec000000-0xedffffff]
[ KERNEL] [ 0.128166] pci 0000:00:01.1: reg 0x14: [mem 0xefff0000-0xefff3fff]
[ KERNEL] [ 0.128387] pci 0000:00:01.1: reg 0x18: [mem 0xeffec000-0xeffeffff]
[ KERNEL] [ 0.128606] pci 0000:00:01.1: reg 0x1c: [mem 0xeffe8000-0xeffebfff]
[ KERNEL] [ 0.128825] pci 0000:00:01.1: reg 0x20: [mem 0xefff8000-0xefffbfff]
[ KERNEL] [ 0.130170] pci 0000:00:01.2: [1022:2082] type 00 class 0x101000
[ KERNEL] [ 0.130484] pci 0000:00:01.2: reg 0x10: [mem 0xefff4000-0xefff7fff]
[ KERNEL] [ 0.132540] pci 0000:00:0d.0: [10ec:8139] type 00 class 0x020000
[ KERNEL] [ 0.132591] pci 0000:00:0d.0: reg 0x10: [io 0xfc00-0xfcff]
[ KERNEL] [ 0.132623] pci 0000:00:0d.0: reg 0x14: [mem 0xeffff000-0xeffff0ff]
[ KERNEL] [ 0.132688] pci 0000:00:0d.0: reg 0x30: [mem 0x00000000-0x0000ffff pref]
[ KERNEL] [ 0.132752] pci 0000:00:0d.0: supports D1 D2
[ KERNEL] [ 0.132772] pci 0000:00:0d.0: PME# supported from D1 D2 D3hot D3cold
[ KERNEL] [ 0.132992] pci 0000:00:0d.0: System wakeup disabled by ACPI
[ KERNEL] [ 0.133536] pci 0000:00:0f.0: [1022:2090] type 00 class 0x060100
[ KERNEL] [ 0.133914] pci 0000:00:0f.0: reg 0x10: [io 0x6000-0x6007]
[ KERNEL] [ 0.134183] pci 0000:00:0f.0: reg 0x14: [io 0x6100-0x61ff]
[ KERNEL] [ 0.134452] pci 0000:00:0f.0: reg 0x18: [io 0x6200-0x623f]
[ KERNEL] [ 0.134723] pci 0000:00:0f.0: reg 0x1c: [io 0x0000-0x001f]
[ KERNEL] [ 0.134998] pci 0000:00:0f.0: reg 0x20: [io 0x9d00-0x9d7f]
[ KERNEL] [ 0.135285] pci 0000:00:0f.0: reg 0x24: [io 0x9c00-0x9c3f]
[ KERNEL] [ 0.136581] pci 0000:00:0f.2: [1022:209a] type 00 class 0x010180
[ KERNEL] [ 0.137618] pci 0000:00:0f.2: reg 0x20: [io 0xff00-0xff0f]
[ KERNEL] [ 0.138067] pci 0000:00:0f.2: legacy IDE quirk: reg 0x10: [io 0x01f0-0x01f7]
[ KERNEL] [ 0.138086] pci 0000:00:0f.2: legacy IDE quirk: reg 0x14: [io 0x03f6]
[ KERNEL] [ 0.138106] pci 0000:00:0f.2: legacy IDE quirk: reg 0x18: [io 0x0170-0x0177]
[ KERNEL] [ 0.138125] pci 0000:00:0f.2: legacy IDE quirk: reg 0x1c: [io 0x0376]
[ KERNEL] [ 0.138969] pci 0000:00:0f.3: [1022:2093] type 00 class 0x040100
[ KERNEL] [ 0.139300] pci 0000:00:0f.3: reg 0x10: [io 0xfe00-0xfe7f]
[ KERNEL] [ 0.141297] pci 0000:00:0f.4: [1022:2094] type 00 class 0x0c0310
[ KERNEL] [ 0.141836] pci 0000:00:0f.4: reg 0x10: [mem 0xefffe000-0xefffefff]
[ KERNEL] [ 0.143334] pci 0000:00:0f.4: PME# supported from D0 D3hot D3cold
[ KERNEL] [ 0.143665] pci 0000:00:0f.4: System wakeup disabled by ACPI
[ KERNEL] [ 0.144440] pci 0000:00:0f.5: [1022:2095] type 00 class 0x0c0320
[ KERNEL] [ 0.144931] pci 0000:00:0f.5: reg 0x10: [mem 0xefffd000-0xefffdfff]
[ KERNEL] [ 0.146418] pci 0000:00:0f.5: PME# supported from D0 D3hot D3cold
[ KERNEL] [ 0.146750] pci 0000:00:0f.5: System wakeup disabled by ACPI
[ KERNEL] [ 0.147320] pci_bus 0000:00: on NUMA node 0
[ KERNEL] [ 0.148828] ACPI: PCI Interrupt Link [LNKA] (IRQs 5 *10 11)
[ KERNEL] [ 0.149720] ACPI: PCI Interrupt Link [LNKB] (IRQs 5 10 *11)
[ KERNEL] [ 0.150467] ACPI: PCI Interrupt Link [LNKC] (IRQs 5 10 11) *0, disabled.
[ KERNEL] [ 0.151353] ACPI: PCI Interrupt Link [LNKD] (IRQs 5 10 11) *0
[ KERNEL] [ 0.156671] ACPI: Enabled 1 GPEs in block 00 to 1F
[ KERNEL] [ 0.157520] ACPI: bus type USB registered
[ KERNEL] [ 0.157822] usbcore: registered new interface driver usbfs
[ KERNEL] [ 0.157978] usbcore: registered new interface driver hub
[ KERNEL] [ 0.158087] usbcore: registered new device driver usb
[ KERNEL] [ 0.158857] wmi: Mapper loaded
[ KERNEL] [ 0.158933] PCI: Using ACPI for IRQ routing
[ KERNEL] [ 0.158948] PCI: pci_cache_line_size set to 32 bytes
[ KERNEL] [ 0.159012] pci 0000:00:01.0: can't claim BAR 0 [io 0xac1c-0xac1f]: no compatible bridge window
[ KERNEL] [ 0.159439] e820: reserve RAM buffer [mem 0x0009e800-0x0009ffff]
[ KERNEL] [ 0.159455] e820: reserve RAM buffer [mem 0x1efb0000-0x1fffffff]
[ KERNEL] [ 0.162716] amd_nb: Cannot enumerate AMD northbridges
[ KERNEL] [ 0.162801] clocksource: Switched to clocksource pit
[ KERNEL] [ 0.163446] pnp: PnP ACPI init
[ KERNEL] [ 0.163446] system 00:00: [mem 0x000f0000-0x000fffff] could not be reserved
[ KERNEL] [ 0.163446] system 00:00: [mem 0x1efb0000-0x1efbffff] could not be reserved
[ KERNEL] [ 0.163446] system 00:00: [mem 0xffff0000-0xffffffff] has been reserved
[ KERNEL] [ 0.163446] system 00:00: [mem 0x00000000-0x0009ffff] could not be reserved
[ KERNEL] [ 0.163446] system 00:00: [mem 0x00100000-0x1efaffff] could not be reserved
[ KERNEL] [ 0.163446] system 00:00: [mem 0xfee00000-0xfee00fff] has been reserved
[ KERNEL] [ 0.163446] system 00:00: Plug and Play ACPI device, IDs PNP0c01 (active)
[ KERNEL] [ 0.163446] pnp 00:01: disabling [io 0x0010-0x001f] because it overlaps 0000:00:0f.0 BAR 3 [io 0x0000-0x001f]
[ KERNEL] [ 0.163672] system 00:01: [io 0x0b78-0x0b7b] has been reserved
[ KERNEL] [ 0.163697] system 00:01: [io 0x0f78-0x0f7b] has been reserved
[ KERNEL] [ 0.163720] system 00:01: [io 0x0a78-0x0a7b] has been reserved
[ KERNEL] [ 0.163742] system 00:01: [io 0x0e78-0x0e7b] has been reserved
[ KERNEL] [ 0.163765] system 00:01: [io 0x0bbc-0x0bbf] has been reserved
[ KERNEL] [ 0.163788] system 00:01: [io 0x0fbc-0x0fbf] has been reserved
[ KERNEL] [ 0.163810] system 00:01: [io 0x04d0-0x04d1] has been reserved
[ KERNEL] [ 0.163837] system 00:01: Plug and Play ACPI device, IDs PNP0c02 (active)
[ KERNEL] [ 0.164184] pnp 00:02: Plug and Play ACPI device, IDs PNP0b00 (active)
[ KERNEL] [ 0.167442] pnp 00:03: Plug and Play ACPI device, IDs PNP0501 (active)
[ KERNEL] [ 0.169104] pnp: PnP ACPI: found 4 devices
[ KERNEL] [ 0.227311] clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
[ KERNEL] [ 0.227929] clocksource: Switched to clocksource acpi_pm
[ KERNEL] [ 0.228012] pci 0000:00:0d.0: BAR 6: assigned [mem 0x1efc0000-0x1efcffff pref]
[ KERNEL] [ 0.228045] pci 0000:00:0f.0: BAR 3: assigned [io 0x1000-0x101f]
[ KERNEL] [ 0.228145] pci_bus 0000:00: resource 4 [io 0x0000-0x0cf7 window]
[ KERNEL] [ 0.228167] pci_bus 0000:00: resource 5 [io 0x0d00-0xac17 window]
[ KERNEL] [ 0.228188] pci_bus 0000:00: resource 6 [io 0xac20-0xffff window]
[ KERNEL] [ 0.228209] pci_bus 0000:00: resource 7 [mem 0x000a0000-0x000bffff window]
[ KERNEL] [ 0.228231] pci_bus 0000:00: resource 8 [mem 0x000c8000-0x000dffff window]
[ KERNEL] [ 0.228253] pci_bus 0000:00: resource 9 [mem 0x1efc0000-0xfebfffff window]
[ KERNEL] [ 0.228451] NET: Registered protocol family 2
[ KERNEL] [ 0.229560] TCP established hash table entries: 4096 (order: 2, 16384 bytes)
[ KERNEL] [ 0.229656] TCP bind hash table entries: 4096 (order: 3, 32768 bytes)
[ KERNEL] [ 0.229769] TCP: Hash tables configured (established 4096 bind 4096)
[ KERNEL] [ 0.229843] UDP hash table entries: 256 (order: 1, 8192 bytes)
[ KERNEL] [ 0.229879] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes)
[ KERNEL] [ 0.230084] NET: Registered protocol family 1
[ KERNEL] [ 0.230243] pci 0000:00:01.1: Video device with shadowed ROM
[ KERNEL] [ 0.232965] ACPI: PCI Interrupt Link [LNKD] BIOS reported IRQ 0, using IRQ 11
[ KERNEL] [ 0.232981] ACPI: PCI Interrupt Link [LNKD] enabled at IRQ 11
[ KERNEL] [ 0.232994] PCI: setting IRQ 11 as level-triggered
[ KERNEL] [ 0.305257] PCI: CLS 32 bytes, default 32
[ KERNEL] [ 0.306509] Trying to unpack rootfs image as initramfs...
[ KERNEL] [ 0.333234] rootfs image is not initramfs (no cpio magic); looks like an initrd
[ KERNEL] [ 0.356183] Freeing initrd memory: 3380K (dec42000 - def8f000)
[ KERNEL] [ 0.358617] futex hash table entries: 256 (order: 2, 16384 bytes)
[ KERNEL] [ 0.387191] romfs: ROMFS MTD (C) 2007 Red Hat, Inc.
[ KERNEL] [ 0.393635] io scheduler noop registered
[ KERNEL] [ 0.393665] io scheduler deadline registered (default)
[ KERNEL] [ 0.394648] input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input0
[ KERNEL] [ 0.394672] ACPI: Power Button [PWRB]
[ KERNEL] [ 0.395096] input: Sleep Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0E:00/input/input1
[ KERNEL] [ 0.395115] ACPI: Sleep Button [SLPB]
[ KERNEL] [ 0.395565] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input2
[ KERNEL] [ 0.395583] ACPI: Power Button [PWRF]
[ KERNEL] [ 0.396733] Warning: Processor Platform Limit event detected, but not handled.
[ KERNEL] [ 0.396747] Consider compiling CPUfreq support into your kernel.
[ KERNEL] [ 0.400569] brd: module loaded
[ KERNEL] [ 0.401943] zram: Added device: zram0
[ KERNEL] [ 0.402003] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ KERNEL] [ 0.402023] ehci-pci: EHCI PCI platform driver
[ KERNEL] [ 0.402709] ehci-pci 0000:00:0f.5: EHCI Host Controller
[ KERNEL] [ 0.402755] ehci-pci 0000:00:0f.5: new USB bus registered, assigned bus number 1
[ KERNEL] [ 0.403053] ehci-pci 0000:00:0f.5: irq 11, io mem 0xefffd000
[ KERNEL] [ 0.412082] ehci-pci 0000:00:0f.5: USB 2.0 started, EHCI 1.00
[ KERNEL] [ 0.412285] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ KERNEL] [ 0.412306] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ KERNEL] [ 0.412325] usb usb1: Product: EHCI Host Controller
[ KERNEL] [ 0.412343] usb usb1: Manufacturer: Linux 4.4.23 ehci_hcd
[ KERNEL] [ 0.412361] usb usb1: SerialNumber: 0000:00:0f.5
[ KERNEL] [ 0.413463] hub 1-0:1.0: USB hub found
[ KERNEL] [ 0.413509] hub 1-0:1.0: 4 ports detected
[ KERNEL] [ 0.414691] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ KERNEL] [ 0.414727] ohci-pci: OHCI PCI platform driver
[ KERNEL] [ 0.415372] ohci-pci 0000:00:0f.4: OHCI PCI host controller
[ KERNEL] [ 0.415417] ohci-pci 0000:00:0f.4: new USB bus registered, assigned bus number 2
[ KERNEL] [ 0.415511] ohci-pci 0000:00:0f.4: irq 11, io mem 0xefffe000
[ KERNEL] [ 0.474223] usb usb2: New USB device found, idVendor=1d6b, idProduct=0001
[ KERNEL] [ 0.474246] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ KERNEL] [ 0.474265] usb usb2: Product: OHCI PCI host controller
[ KERNEL] [ 0.474283] usb usb2: Manufacturer: Linux 4.4.23 ohci_hcd
[ KERNEL] [ 0.474301] usb usb2: SerialNumber: 0000:00:0f.4
[ KERNEL] [ 0.475401] hub 2-0:1.0: USB hub found
[ KERNEL] [ 0.475453] hub 2-0:1.0: 4 ports detected
[ KERNEL] [ 0.476577] uhci_hcd: USB Universal Host Controller Interface driver
[ KERNEL] [ 0.477363] i8042: PNP: No PS/2 controller found. Probing ports directly.
[ KERNEL] [ 0.480532] serio: i8042 KBD port at 0x60,0x64 irq 1
[ KERNEL] [ 0.480569] serio: i8042 AUX port at 0x60,0x64 irq 12
[ KERNEL] [ 0.481413] hv_vmbus: registering driver hyperv_keyboard
[ KERNEL] [ 0.481784] mousedev: PS/2 mouse device common for all mice
[ KERNEL] [ 0.483994] input: PC Speaker as /devices/platform/pcspkr/input/input4
[ KERNEL] [ 0.484802] hidraw: raw HID events driver (C) Jiri Kosina
[ KERNEL] [ 0.485885] hv_vmbus: registering driver hid_hyperv
[ KERNEL] [ 0.488885] usbcore: registered new interface driver usbhid
[ KERNEL] [ 0.488900] usbhid: USB HID core driver
[ KERNEL] [ 0.489325] NET: Registered protocol family 17
[ KERNEL] [ 0.489368] mce: Unable to init device /dev/mcelog (rc: -5)
[ KERNEL] [ 0.489617] Using IPI No-Shortcut mode
[ KERNEL] [ 0.896245] RAMDISK: xz image found at block 0
[ KERNEL] [ 1.013056] usb 2-1: new full-speed USB device number 2 using ohci-pci
[ KERNEL] [ 1.217746] usb 2-1: New USB device found, idVendor=1a86, idProduct=7523
[ KERNEL] [ 1.217774] usb 2-1: New USB device strings: Mfr=0, Product=2, SerialNumber=0
[ KERNEL] [ 1.217792] usb 2-1: Product: USB2.0-Ser!
[ KERNEL] [ 1.356751] tsc: Refined TSC clocksource calibration: 498.619 MHz
[ KERNEL] [ 1.356782] clocksource: tsc: mask: 0xffffffffffffffff max_cycles: 0xe5fe5e9335, max_idle_ns: 881590418043 ns
[ KERNEL] [ 1.356831] clocksource: Switched to clocksource tsc
[ KERNEL] [ 1.524462] usb 2-3: new full-speed USB device number 3 using ohci-pci
[ KERNEL] [ 1.725193] usb 2-3: config 1 interface 0 altsetting 0 endpoint 0x85 has an invalid bInterval 0, changing to 10
[ KERNEL] [ 1.734460] usb 2-3: New USB device found, idVendor=11ca, idProduct=0222
[ KERNEL] [ 1.734484] usb 2-3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ KERNEL] [ 1.734502] usb 2-3: Product: Trident USB Device 1.1
[ KERNEL] [ 1.734520] usb 2-3: Manufacturer: VeriFone Inc
[ KERNEL] [ 5.326504] VFS: Mounted root (romfs filesystem) readonly on device 1:0.
[ KERNEL] [ 5.326603] devtmpfs: mounted
[ KERNEL] [ 5.327155] Freeing unused kernel memory: 380K (c14e6000 - c1545000)
[ KERNEL] [ 5.327791] Write protecting the kernel text: 3792k
[ KERNEL] [ 5.327962] Write protecting the kernel read-only data: 1012k
[ pfac] [ 6.013911] Run /sbin/initrd.
[ pfac] [ 6.014075] Ok, PID 514.
[ initrd] [ 6.017182] WTware shell v.5.4.52
[ initrd] [ 16.272201] Keyboard not found.
[ initrd] [ 16.272342] Load ethernet drivers.
[ initrd] [ 16.276827] modprobe 8139too.
[ KERNEL] [ 16.287403] 8139too: 8139too Fast Ethernet driver 0.9.28
[ KERNEL] [ 16.295043] ACPI: PCI Interrupt Link [LNKB] enabled at IRQ 11
[ initrd] [ 16.298688] NIC module 8139too.ko loaded.
[ KERNEL] [ 16.296870] 8139too 0000:00:0d.0 eth0: RealTek RTL8139 at 0x0001fc00, 00:1a:a9:e7:1b:e4, IRQ 11
[ initrd] [ 16.298896] modprobe 8139cp.
[ initrd] [ 16.320194] NIC module 8139cp.ko loaded.
[ initrd] [ 16.374229] eth0: 10ec:8139. Apply WOL configuration.
[ KERNEL] [ 16.373230] 8139too 0000:00:0d.0 eth0: link up, 100Mbps, full-duplex, lpa 0xC1E1
[ initrd] [ 16.375267] dhcp: 328 bytes from 172.16.99.1.
[ initrd] [ 16.375365] 00000000:000001340000000000110000ac106301ac1063e9004300440134000002010600 ...4........c..c..C.D.4......
[ initrd] [ 16.375454] 00000020:67458b6b0000000000000000ac1063e90a00646500000000001aa9e71be40000 gE.k.........c...de..........
[ initrd] [ 16.375538] 00000040:0000000000000000000000000000000000000000000000000000000000000000 ................................
[ initrd] [ 16.375622] 00000060:0000000000000000000000000000000000000000000000000000000000000000 ................................
[ initrd] [ 16.676507] dhcp: 328 bytes from 172.16.99.1.
[ initrd] [ 16.677069] 00000000:000001340000000000110000ac106301ac1063e9004300440134000002010600 ...4........c..c..C.D.4......
[ initrd] [ 16.677189] 00000020:67458b6b0000000000000000ac1063e90a00646500000000001aa9e71be40000 gE.k.........c...de..........
[ initrd] [ 16.677277] 00000040:0000000000000000000000000000000000000000000000000000000000000000 ................................
[ initrd] [ 16.677361] 00000060:0000000000000000000000000000000000000000000000000000000000000000 ................................
[ initrd] [ 16.677446] dhcp: server address 172.16.99.1.
[ initrd] [ 16.677529] dhcp: 172.16.99.233/255.255.255.0.
[ initrd] [ 16.677612] dhcp: default gateway 172.16.99.1.
[ initrd] [ 16.677694] dhcp: DNS 10.0.90.10.
[ initrd] [ 16.677776] dhcp: DNS 10.0.100.11.
[ initrd] [ 16.677859] dhcp: DNS 10.0.100.10.
[ initrd] [ 16.677941] dhcp: domain тутадресдомена.
[ initrd] [ 16.678022] dhcp: TFTP from siaddr 10.0.100.101.
[ initrd] [ 16.678105] dhcp: TFTP 10.0.100.101.
[ initrd] [ 16.678187] dhcp: boot file (header) 5.4.52/wtware.pxe.
[ initrd] [ 16.678269] TFTP binary "5.4.52/", configs prefix "", using "/" slash.
Send broadcast WTCU discover.
[ initrd] [ 18.275350] [TFTP] Download and unpack file 5.4.52/packages/lib6 from 10.0.100.101.
[ initrd] [ 18.283160] WTware TFTP v.5.4.52.
[ initrd] [ 20.462932] Run '/sbin/httpd', log '/tmp/httpd.out', env '', pid ''.
[ pfac] [ 20.463554] Run /sbin/httpd.
[ pfac] [ 20.463665] Ok, PID 536.
[ KERNEL] [ 20.484359] random: httpd: uninitialized urandom read (48 bytes read, 99 bits of entropy available)
[ httpd] [ 20.486248] HTTP Server, WTware v.5.4.52
[ initrd] [ 20.706544] PCI: C 06 1022:2080 Bridge Advanced Micro Devices, Inc. [AMD] CS5536 [Geode companion] Host Bridge.
[ initrd] [ 20.706773] PCI: C 03 1022:2081 Display controller Advanced Micro Devices, Inc. [AMD] Geode LX Video.
[ initrd] [ 20.706944] PCI: C 10:10 1022:2082 Encryption controller Entertainment encryption device Advanced Micro Devices, Inc. [AMD] Geode LX AES Security Block.
[ initrd] [ 20.707106] PCI: C 02 10ec:8139 Network controller Realtek Semiconductor Co., Ltd. RTL-8100/8101L/8139 PCI Fast Ethernet Adapter.
[ initrd] [ 20.707269] PCI: C 06:01 1022:2090 Bridge ISA bridge Advanced Micro Devices, Inc. [AMD] CS5536 [Geode companion] ISA.
[ initrd] [ 20.707435] PCI: C 01:01 1022:209a Mass storage controller IDE interface Advanced Micro Devices, Inc. [AMD] CS5536 [Geode companion] IDE.
[ initrd] [ 20.707601] PCI: C 04:01 1022:2093 Multimedia controller Multimedia audio controller Advanced Micro Devices, Inc. [AMD] CS5536 [Geode companion] Audio.
[ initrd] [ 20.707766] PCI: C 0c:03 1022:2094 Serial bus controller USB controller Advanced Micro Devices, Inc. [AMD] CS5536 [Geode companion] OHC.
[ initrd] [ 20.707931] PCI: C 0c:03 1022:2095 Serial bus controller USB controller Advanced Micro Devices, Inc. [AMD] CS5536 [Geode companion] EHC.
[ initrd] [ 20.835712] USB: 1a86:7523 QinHeng Electronics HL-340 USB-Serial adapter.
[ initrd] [ 20.835919] USB: 11ca:0222 VeriFone Inc.
[ initrd] [ 20.836219] [TFTP] Download file Everyone/list.wtc from 10.0.100.101.
| # Список подключаемых файлов.
| # Этот отдельный механизм настройки терминалов предназначен только
| # для ручного конфигурирования терминалов. Графический конфигуратор
| # не читает list.wtc, не читает и не позволяет редактировать файлы
| # из каталога ListIncludes. Поэтому нельзя пытаться настраивать один
| # и тот же терминал и конфигуратором, и через list.wtc.
| # Формат строки в этом файле:
| # 01.02.03.04.05.06[([имяпользователя@][имятерминала])] [файл [файл ...]]] [# комментарий]
| # Примеры:
| # 02.03.04.05.06.07 file1
| # Означает, что терминал с мак-адресом 02.03.04.05.06.07 прочитает
| # параметры из файла ListIncludes/file1.
| # Означает, что терминал с мак-адресом 03.04.05.06.07.08 прочитает
| # параметры из файла ListIncludes/file2 и в окошко "Вход в Windows"
| # подставит имя пользователя "vasja".
| # 04.05.06.07.08.09(term5) file6 file7 # Комп замглавбуха.
| # Означает, что терминалу с мак-адресом 04.05.06.07.08.09 будет
| # присвоено имя term5, аналогично указанию параметра clienthostname,
| # и он прочитает параметры из файлов ListIncludes/file6 и
| # ListIncludes/file7.
| # Чтобы можно было указывать имя пользователя русскими буквами, надо
| # открыть этот файл в Notepad и сохранить с Encoding: Unicode.
[ initrd] [ 20.844168] [TFTP] Download file Terminals/00.1A.A9.E7.1B.E4/config.wtc from 10.0.100.101.
[ initrd] [ 20.846254] [TFTP] Download file Terminals/00.1A.A9.E7.1B.E4/wtware.lic from 10.0.100.101.
[ initrd] [ 20.849111] [TFTP] Error code 1: File not found..
| video=VESA(F)
| bpp=16
| display=1280x1024
| server=smr-srv-000007
| user=тутадресдомена\имяпользователя[имяпользователя]:пароль
| serial=COM4(usb)
| autoshutdown=0
| connection
[ initrd] [ 20.849863] [TFTP] Download file Everyone/all.wtc from 10.0.100.101.
| [BOM]
| vnc=on
| vnc_password=hex:4b3ce963a8267ef2ed75317b2c828dcc
| skin=avias-01
| autoshutdown=5
[ initrd] [ 20.852363] [TFTP] Download file Everyone/wtware.lic from 10.0.100.101.
| [BOM]
| vnc=on
| skin=avias-01
| autoshutdown=0
| video=VESA(F)
| bpp=16
| display=1280x1024
| serial=COM4(usb)
| connection
| license_00:1a:a9:e7:1b:e4_full = \
| 027461db2cbfab4c474af4c35f43302d0d1e99ca4ff91c955fa5be441a609687 \
| 2433bfa84550cd54472396debd8085db8cf65ebfd19b43055ee72f01790f7464 \
| eebe5eddc32c1b4023e465f484e2cec7ea3ddef15c44fe78f1bf632a721674e4 \
| 33b5d2fa1d43454d6e09c15982d1df9143f8aa1b0d4009ca52a9afad676824eb
[ initrd] [ 20.876347] Hostname: "wtw001AA9E71BE4".
RSH: listener is active.
[ httpd] [ 20.885319] Reread settings.
[ httpd] [ 20.885442] Everyone can control terminal by HTTP.
[ initrd] [ 20.885783] [TFTP] Download and unpack file 5.4.52/packages/f from 10.0.100.101.
[ KERNEL] [ 21.711724] random: nonblocking pool is initialized
[ initrd] [ 23.999913] [TFTP] Download and unpack file 5.4.52/packages/fwt6 from 10.0.100.101.
[ initrd] [ 24.524590] [TFTP] Download and unpack file 5.4.52/packages/graphic from 10.0.100.101.
[ gm] [ 24.591141] WTware session manager v.5.4.52.
[ gm] [ 24.594232] Ignore event3: PC Speaker.
[ gm] [ 24.594475] Add keyboard event2: Power Button.
[ gm] [ 24.594682] Add keyboard event1: Sleep Button.
[ gm] [ 24.594874] Add keyboard event0: Power Button.
[ gm] [ 24.595295] Display mode: 1280x1024, 16 bit, 0 Hz, modeline "", DDC enabled, connector 0.
[ gm] [ 28.448788] VBE Version 2.0.
[ gm] [ 28.448990] VBE modelist at 0x00011127.
[ gm] [ 28.449264] Call _emulate ().
[ gm] [ 28.449473] Mode 257: 640x480 (256 color palette) linelength 640 bits 8.
[ gm] [ 28.449792] Mode 259: 800x600 (256 color palette) linelength 800 bits 8.
[ gm] [ 28.450119] Mode 261: 1024x768 (256 color palette) linelength 1024 bits 8.
[ gm] [ 28.450449] Mode 263: 1280x1024 (256 color palette) linelength 1280 bits 8.
[ gm] [ 28.450779] Mode 272: 640x480 (5:5:5) linelength 1280 bits 15.
[ gm] [ 28.451115] Mode 273: 640x480 (5:6:5) linelength 1280 bits 16.
[ gm] [ 28.451453] Mode 274: 640x480 (8:8:8) linelength 2560 bits 32.
[ gm] [ 28.451789] Mode 275: 800x600 (5:5:5) linelength 1600 bits 15.
[ gm] [ 28.452225] Mode 276: 800x600 (5:6:5) linelength 1600 bits 16.
[ gm] [ 28.452577] Mode 277: 800x600 (8:8:8) linelength 3200 bits 32.
[ gm] [ 28.452922] Mode 278: 1024x768 (5:5:5) linelength 2048 bits 15.
[ gm] [ 28.453271] Mode 279: 1024x768 (5:6:5) linelength 2048 bits 16.
[ gm] [ 28.453622] Mode 280: 1024x768 (8:8:8) linelength 4096 bits 32.
[ gm] [ 28.453972] Mode 281: 1280x1024 (5:5:5) linelength 2560 bits 15.
[ gm] [ 28.454326] Mode 282: 1280x1024 (5:6:5) linelength 2560 bits 16.
[ gm] [ 28.454473] Use mode 282.
[ gm] [ 28.454824] Mode 283: 1280x1024 (8:8:8) linelength 5120 bits 32.
[ gm] [ 28.455247] Mode 289: 320x240 (256 color palette) linelength 320 bits 8.
[ gm] [ 28.455673] Mode 290: 320x240 (5:5:5) linelength 640 bits 15.
[ gm] [ 28.456174] Mode 291: 320x240 (5:6:5) linelength 640 bits 16.
[ gm] [ 28.456616] Mode 292: 320x240 (8:8:8) linelength 1280 bits 32.
[ gm] [ 28.457002] Mode 293: 1152x864 (256 color palette) linelength 1152 bits 8.
[ gm] [ 28.457392] Mode 294: 1152x864 (5:5:5) linelength 2304 bits 15.
[ gm] [ 28.457784] Mode 295: 1152x864 (5:6:5) linelength 2304 bits 16.
[ gm] [ 28.458176] Mode 296: 1152x864 (8:8:8) linelength 4608 bits 32.
[ gm] [ 28.458543] Mode 305: 1600x1200 (256 color palette) linelength 1600 bits 8.
[ gm] [ 28.458915] Mode 306: 1600x1200 (5:5:5) linelength 3200 bits 15.
[ gm] [ 28.459286] Mode 307: 1600x1200 (5:6:5) linelength 3200 bits 16.
[ gm] [ 28.459662] Mode 308: 1600x1200 (8:8:8) linelength 6400 bits 32.
[ gm] [ 28.460103] Mode 309: 1920x1440 (256 color palette) linelength 1920 bits 8.
[ gm] [ 28.460512] Mode 310: 1920x1440 (5:5:5) linelength 3840 bits 15.
[ gm] [ 28.460901] Mode 311: 1920x1440 (5:6:5) linelength 3840 bits 16.
[ gm] [ 28.461285] Mode 312: 1920x1440 (8:8:8) linelength 7680 bits 32.
[ gm] [ 28.647411] Linear framebuffer.
[ gm] [ 28.647660] 0x4f01 failed. Try again.
[ gm] [ 28.648196] mmap () return 0xb72d4000. Touch video memory.
[ gm] [ 28.648351] Ok.
[ gm] [ 28.648520] MTRR not found.
[ gm] [ 28.651551] [TFTP] Download file Graphic/avias-01/wait.png from 10.0.100.101.
[ gm] [ 28.778914] /tmp/wait.png: 800x600.
[ gm] [ 28.992257] WMEMCOPY: 25600K copied in 0.166949 sec.
[ gm] [ 29.173360] libc: 25600K copied in 0.180784 sec.
[ gm] [ 29.282380] movs: 25600K copied in 0.108716 sec.
[ gm] [ 29.384857] MMX: 25600K copied in 0.102175 sec.
[ gm] [ 29.385055] Choose MMX memcpy.
[ gm] [ 29.395731] [TFTP] Download file Graphic/avias-01/popup.png from 10.0.100.101.
[ gm] [ 29.430965] Run serial daemon for ttyACM0.
[ gm] [ 29.431151] Run '/sbin/rdpdr[serial] 12', log '', env '', pid ''.
[ pfac] [ 29.431784] Run /sbin/rdpdr[serial] 12.
[ pfac] [ 29.431905] Ok, PID 540.
[ gm] [ 29.432191] Run serial daemon for ttyUSB0.
[ gm] [ 29.432354] Run '/sbin/rdpdr[serial] 8', log '', env '', pid ''.
[ pfac] [ 29.432902] Run /sbin/rdpdr[serial] 8.
[ pfac] [ 29.433020] Ok, PID 541.
[ gm] [ 29.433393] Load usb <-> serial bridges drivers.
[ gm] [ 29.443190] modprobe usbserial.
[rdpdr-serial 12] [ 29.443351] RDP Serial Port Redirector, WTware v.5.4.52, device ttyACM0.
[rdpdr-serial 8] [ 29.443686] RDP Serial Port Redirector, WTware v.5.4.52, device ttyUSB0.
[ KERNEL] [ 29.455363] usbcore: registered new interface driver usbserial
[ KERNEL] [ 29.455533] usbcore: registered new interface driver usbserial_generic
[ KERNEL] [ 29.455688] usbserial: USB Serial support registered for generic
[ gm] [ 29.457747] modprobe pl2303.
[ gm] [ 29.482145] modprobe ftdi_sio.
[ KERNEL] [ 29.480328] usbcore: registered new interface driver pl2303
[ KERNEL] [ 29.480510] usbserial: USB Serial support registered for pl2303
[ gm] [ 29.507327] modprobe cp210x.
[ KERNEL] [ 29.505006] usbcore: registered new interface driver ftdi_sio
[ KERNEL] [ 29.505188] usbserial: USB Serial support registered for FTDI USB Serial Device
[ gm] [ 29.527593] modprobe ch341.
[ KERNEL] [ 29.525724] usbcore: registered new interface driver cp210x
[ KERNEL] [ 29.525917] usbserial: USB Serial support registered for cp210x
[ KERNEL] [ 29.545225] usbcore: registered new interface driver ch341
[ KERNEL] [ 29.545411] usbserial: USB Serial support registered for ch341-uart
[ KERNEL] [ 29.545518] ch341 2-1:1.0: ch341-uart converter detected
[ gm] [ 29.570090] modprobe metro-usb.
[ KERNEL] [ 29.568420] usb 2-1: ch341-uart converter now attached to ttyUSB0
[ KERNEL] [ 29.583273] usbcore: registered new interface driver metro_usb
[ KERNEL] [ 29.583459] usbserial: USB Serial support registered for Metrologic USB to Serial
[ gm] [ 29.585445] modprobe symbolserial.
[ KERNEL] [ 29.603240] usbcore: registered new interface driver symbolserial
[ KERNEL] [ 29.603425] usbserial: USB Serial support registered for symbol
[ gm] [ 29.605396] modprobe opticon.
[ gm] [ 29.624871] modprobe cdc-acm.
[ KERNEL] [ 29.622986] usbcore: registered new interface driver opticon
[ KERNEL] [ 29.623175] usbserial: USB Serial support registered for opticon
[ KERNEL] [ 29.643823] cdc_acm 2-3:1.0: ttyACM0: USB ACM device
[ gm] [ 29.646650] modprobe mxu11x0.
[ KERNEL] [ 29.645099] usbcore: registered new interface driver cdc_acm
[ KERNEL] [ 29.645117] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[ KERNEL] [ 29.665752] usbcore: registered new interface driver mxu11x0
[ KERNEL] [ 29.665930] usbserial: USB Serial support registered for MOXA UPort 1110
[ KERNEL] [ 29.666083] usbserial: USB Serial support registered for MOXA UPort 1130
[ KERNEL] [ 29.666240] usbserial: USB Serial support registered for MOXA UPort 1150
[ KERNEL] [ 29.666399] usbserial: USB Serial support registered for MOXA UPort 1150I
[ KERNEL] [ 29.666557] usbserial: USB Serial support registered for MOXA UPort 1130I
[ KERNEL] [ 29.666578] mxu11x0: 1.3.11:MOXA UPort 11x0 USB to Serial Hub Driver
[ gm] [ 29.736532] Run '/sbin/resolver 0x8fb3e00 dns [smr-srv-000007]', log '', env '', pid ''.
[ pfac] [ 29.737245] Run /sbin/resolver 0x8fb3e00 dns [smr-srv-000007].
[ pfac] [ 29.737367] Ok, PID 600.
[ gm] [ 29.737608] Everyone can control terminal by VNC.
[ gm] [ 29.737876] VNC listener at port 5900.
[ pfac] [ 29.751510] Process pid 600 terminated, status 00000000.
[ gm] [ 29.755770] smr-srv-000007 => 10.0.100.107.
[ gm] [ 29.756228] Free ram before fork terminal client /sbin/rdpclient (session 1): 475612 Kb.
[ gm] [ 29.756422] Run '/sbin/rdpclient 1', log '/tmp/rdpclient.out', env '', pid ''.
[ pfac] [ 29.757028] Run /sbin/rdpclient 1.
[ pfac] [ 29.757147] Ok, PID 601.
[ rdpclient 601] [ 29.770378] RDP Terminal Client, WTware v.5.4.52, pipe 1, pid 601.
[ gm] [ 29.771724] COM4 => ttyACM0, single device.
[ rdpclient 601] [ 29.773224] Add serial redirection, COM4 in the session = hardware ttyACM0.
[rdpdr-serial 12] [ 29.774015] New client connection, id 1.
[ rdpclient 601] [ 29.774306] Make RDP session with 10.0.100.107, port 3389.
[ rdpclient 601] [ 29.774463] Username: "test".
[ rdpclient 601] [ 29.774606] Password: present.
[ rdpclient 601] [ 29.774747] No PIN.
[ rdpclient 601] [ 29.774889] Domain: "тутадресдомена".
[ rdpclient 601] [ 29.775029] No shell.
[ rdpclient 601] [ 29.775168] No directory.
[ rdpclient 601] [ 29.775312] Window: 1280x1024@16.
[ rdpclient 601] [ 29.775484] PFlags 0x0000002F.
[ rdpclient 601] [ 29.775632] Keyboard 00000409:00000000.
[ rdpclient 601] [ 29.775776] My hostname "wtw001AA9E71BE4".
[ rdpclient 601] [ 29.775923] TCP: connecting to 10.0.100.107:3389.
[ rdpclient 601] [ 29.777089] TCP: connection with 10.0.100.107:3389 established.
[ rdpclient 601] [ 29.777279] Turn keepalive on.
[ rdpclient 601] [ 29.778517] Free ram after buffers allocation: 475452 KB.
[ rdpclient 601] [ 29.785997] Process RDP server certificate.
[ rdpclient 601] [ 29.786193] RDP5 encryption (X.509).
[ rdpclient 601] [ 30.587271] errorInfo 0x00000000.
[ rdpclient 601] [ 31.028426] SessionId 0x00000005: тутадресдомена\test.
