Настройка кластера Wtware
Добавлено: Пт апр 29, 2022 1:52 pm
Здравствуйте, имеется 2 терминальных сервера в домене. Wtware 6.0.72 установлен на контроллере домена. На терминальных серверах работает служба wtlb. При подключении все машины грузит на один сервер, тот который указан первым в настройках.
Логи wtlb 1 сервер:
29.04.2022 11:27:26 (INFO): Debug info will be stored in this file.
29.04.2022 11:27:26 (SUCCESS): Member of cluster 'terminal', autosearch: on.
29.04.2022 11:27:26 (SUCCESS): Balancing by CPU load, ratio 1.
29.04.2022 11:27:27 (SUCCESS): Domain controller: \\ADVSP1.
29.04.2022 11:27:27 (INFO): Total 1 IP's will be used.
29.04.2022 11:27:27 (INFO): My IP #0 is 10.36.64.11/255.255.0.0.
29.04.2022 11:27:27 (INFO): Starting WTware Terminal Services Load Balancing service.
29.04.2022 11:27:27 (INFO): My IP is 10.36.64.11.
29.04.2022 11:27:27 (INFO): Send broadcast notice to 10.36.255.255.
29.04.2022 11:27:27 (INFO): Packet from 10.36.64.11 received, 184 bytes.
29.04.2022 11:27:27 (INFO): Data from cluster 'terminal' received, 5 bytes.
29.04.2022 11:27:27 (INFO): packetServerNotice from 10.36.64.11.
29.04.2022 11:27:27 (INFO): Cool, message from ourself received.
29.04.2022 11:27:27 (INFO): Packet from 10.36.64.12 received, 184 bytes.
29.04.2022 11:27:27 (INFO): packetServerNeighList from 10.36.64.12, 0 items.
29.04.2022 11:27:27 (INFO): New server added: 10.36.64.12.
29.04.2022 11:32:54 (INFO): Packet from 10.36.64.12 received, 184 bytes.
29.04.2022 11:32:54 (INFO): Data from cluster 'terminal' received, 5 bytes.
29.04.2022 11:32:54 (INFO): packetServerNotice from 10.36.64.12.
29.04.2022 11:32:54 (INFO): Send list of 1 found ip's for the cluster 'terminal' by broadcast notice to the subnet 10.36.255.255.
29.04.2022 11:32:54 (INFO): Packet from 10.36.64.11 received, 192 bytes.
29.04.2022 11:32:54 (INFO): Data from cluster 'terminal' received, 9 bytes.
29.04.2022 11:32:54 (INFO): packetServerNeighList from 10.36.64.11, 1 items.
29.04.2022 11:32:54 (INFO): Cool, message from ourself received.
Логи wtlb 2 сервер:
29.04.2022 11:32:53 (INFO): Debug info will be stored in this file.
29.04.2022 11:32:53 (SUCCESS): Member of cluster 'terminal', autosearch: on.
29.04.2022 11:32:53 (SUCCESS): Balancing by CPU load, ratio 1.
29.04.2022 11:32:54 (SUCCESS): Domain controller: \\ADVSP1.
29.04.2022 11:32:54 (INFO): Total 1 IP's will be used.
29.04.2022 11:32:54 (INFO): My IP #0 is 10.36.64.12/255.255.0.0.
29.04.2022 11:32:54 (INFO): Starting WTware Terminal Services Load Balancing service.
29.04.2022 11:32:54 (INFO): My IP is 10.36.64.12.
29.04.2022 11:32:54 (INFO): Send broadcast notice to 10.36.255.255.
29.04.2022 11:32:54 (INFO): New server added: 10.36.64.11.
Логи терминала:
12-44-17-131| [TFTP] "6.0.72\wtware.http": completed.
12-44-20-225| [TFTP] RRQ 50 bytes:
12-44-20-225| [TFTP] 00000000: 36 2e 30 2e 37 32 2f 77 74 77 61 72 65 2e 68 74
12-44-20-225| [TFTP] 00000010: 74 70 2e 63 66 67 00 6f 63 74 65 74 00 62 6c 6b
12-44-20-225| [TFTP] 00000020: 73 69 7a 65 00 31 34 33 32 00 74 73 69 7a 65 00
12-44-20-225| [TFTP] 00000030: 30 00
12-44-20-225| [TFTP] Request block size 1432, interface MTU 1500.
12-44-20-225| [TFTP] "6.0.72\wtware.http.cfg": tsize is requested, blksize 1432 bytes.
12-44-20-225| [TFTP] "6.0.72\wtware.http.cfg": "C:\Program Files (x86)\WTware\TFTPDROOT\6.0.72\wtware.http.cfg".
12-44-20-225| [TFTP] "6.0.72\wtware.http.cfg": completed.
12-44-20-241| [HTTP] '/wtware/6.0.72\packages\kernel' => 'C:\Program Files (x86)\WTware\TFTPDROOT\6.0.72\packages\kernel'.
12-44-26-163| [HTTP] WTware v.6.0.72 found at host [], mac 08:00:27:24:0E:28.
12-44-26-178| [HTTP] '/wtware/6.0.72\packages\lib6' => 'C:\Program Files (x86)\WTware\TFTPDROOT\6.0.72\packages\lib6'.
12-44-26-522| [HTTP] '/wtware/Everyone\source.wtc' => 'C:\ProgramData\WTware\Everyone\source.wtc'.
12-44-26-522| [HTTP] '/wtware/Everyone\list.wtc' => 'C:\ProgramData\WTware\Everyone\list.wtc'.
12-44-26-538| [HTTP] '/wtware/Terminals\08.00.27.24.0E.28\config.wtc' => 'C:\ProgramData\WTware\Terminals\08.00.27.24.0E.28\config.wtc'.
12-44-26-538| [HTTP] '/wtware/Terminals\08.00.27.24.0E.28\wtware.lic' => 'C:\ProgramData\WTware\Terminals\08.00.27.24.0E.28\wtware.lic'.
12-44-26-538| [HTTP] Failed to open file.
12-44-26-538| [HTTP] '/wtware/Everyone\all.wtc' => 'C:\ProgramData\WTware\Everyone\all.wtc'.
12-44-26-538| [HTTP] '/wtware/Everyone\wtware.lic' => 'C:\ProgramData\WTware\Everyone\wtware.lic'.
12-44-26-538| [HTTP] '/wtware/6.0.72\packages\f-drm' => 'C:\Program Files (x86)\WTware\TFTPDROOT\6.0.72\packages\f-drm'.
12-44-26-569| [HTTP] '/wtware/6.0.72\packages\fwt6' => 'C:\Program Files (x86)\WTware\TFTPDROOT\6.0.72\packages\fwt6'.
12-44-26-678| [HTTP] '/wtware/6.0.72\packages\f' => 'C:\Program Files (x86)\WTware\TFTPDROOT\6.0.72\packages\f'.
12-44-26-710| [HTTP] '/wtware/6.0.72\packages\graphic' => 'C:\Program Files (x86)\WTware\TFTPDROOT\6.0.72\packages\graphic'.
12-56-59-224| WTware 6.0.72 supervisor.
12-56-59-224| [ KERNEL] [ 0.000000] Linux version 4.19.225 (aka@c25) (gcc version 10.2.1 20210110 (Debian 10.2.1-6)) #13 SMP Mon Jan 24 00:12:23 +04 2022
12-56-59-224| [ KERNEL] [ 0.000000] [Firmware Bug]: TSC doesn't count with P0 frequency!
12-56-59-224| [ KERNEL] [ 0.000000] x86/fpu: Supporting XSAVE feature 0x001: 'x87 floating point registers'
12-56-59-224| [ KERNEL] [ 0.000000] x86/fpu: Supporting XSAVE feature 0x002: 'SSE registers'
12-56-59-224| [ KERNEL] [ 0.000000] x86/fpu: Supporting XSAVE feature 0x004: 'AVX registers'
12-56-59-224| [ KERNEL] [ 0.000000] x86/fpu: xstate_offset[2]: 576, xstate_sizes[2]: 256
12-56-59-224| [ KERNEL] [ 0.000000] x86/fpu: Enabled xstate features 0x7, context size is 832 bytes, using 'standard' format.
12-56-59-224| [ KERNEL] [ 0.000000] BIOS-provided physical RAM map:
12-56-59-224| [ KERNEL] [ 0.000000] BIOS-e820: [mem 0x0000000000000000-0x000000000009fbff] usable
12-56-59-224| [ KERNEL] [ 0.000000] BIOS-e820: [mem 0x000000000009fc00-0x000000000009ffff] reserved
12-56-59-224| [ KERNEL] [ 0.000000] BIOS-e820: [mem 0x00000000000f0000-0x00000000000fffff] reserved
12-56-59-224| [ KERNEL] [ 0.000000] BIOS-e820: [mem 0x0000000000100000-0x000000003ffeffff] usable
12-56-59-224| [ KERNEL] [ 0.000000] BIOS-e820: [mem 0x000000003fff0000-0x000000003fffffff] ACPI data
12-56-59-224| [ KERNEL] [ 0.000000] BIOS-e820: [mem 0x00000000fec00000-0x00000000fec00fff] reserved
12-56-59-224| [ KERNEL] [ 0.000000] BIOS-e820: [mem 0x00000000fee00000-0x00000000fee00fff] reserved
12-56-59-224| [ KERNEL] [ 0.000000] BIOS-e820: [mem 0x00000000fffc0000-0x00000000ffffffff] reserved
12-56-59-224| [ KERNEL] [ 0.000000] Notice: NX (Execute Disable) protection cannot be enabled: non-PAE kernel!
12-56-59-224| [ KERNEL] [ 0.000000] SMBIOS 2.5 present.
12-56-59-224| [ KERNEL] [ 0.000000] DMI: innotek GmbH VirtualBox/VirtualBox, BIOS VirtualBox 12/01/2006
12-56-59-224| [ KERNEL] [ 0.000000] tsc: Fast TSC calibration using PIT
12-56-59-224| [ KERNEL] [ 0.000000] tsc: Detected 3291.780 MHz processor
12-56-59-224| [ KERNEL] [ 0.000586] e820: update [mem 0x00000000-0x00000fff] usable ==> reserved
12-56-59-224| [ KERNEL] [ 0.000587] e820: remove [mem 0x000a0000-0x000fffff] usable
12-56-59-224| [ KERNEL] [ 0.000590] last_pfn = 0x3fff0 max_arch_pfn = 0x100000
12-56-59-224| [ KERNEL] [ 0.000599] MTRR default type: uncachable
12-56-59-224| [ KERNEL] [ 0.000600] MTRR variable ranges disabled:
12-56-59-224| [ KERNEL] [ 0.000601] Disabled
12-56-59-224| [ KERNEL] [ 0.000602] x86/PAT: MTRRs disabled, skipping PAT initialization too.
12-56-59-224| [ KERNEL] [ 0.000603] CPU MTRRs all blank - virtualized system.
12-56-59-224| [ KERNEL] [ 0.000605] x86/PAT: Configuration [0-7]: WB WT UC- UC WB WT UC- UC
12-56-59-224| [ KERNEL] [ 0.000623] found SMP MP-table at [mem 0x0009fff0-0x0009ffff]
12-56-59-224| [ KERNEL] [ 0.000627] initial memory mapped: [mem 0x00000000-0x01ffffff]
12-56-59-224| [ KERNEL] [ 0.000701] ACPI: Early table checksum verification disabled
12-56-59-224| [ KERNEL] [ 0.000708] ACPI: RSDP 0x00000000000E0000 000024 (v02 VBOX )
12-56-59-224| [ KERNEL] [ 0.000711] ACPI: XSDT 0x000000003FFF0030 00003C (v01 VBOX VBOXXSDT 00000001 ASL 00000061)
12-56-59-224| [ KERNEL] [ 0.000714] ACPI: FACP 0x000000003FFF00F0 0000F4 (v04 VBOX VBOXFACP 00000001 ASL 00000061)
12-56-59-224| [ KERNEL] [ 0.000717] ACPI: DSDT 0x000000003FFF0470 002325 (v02 VBOX VBOXBIOS 00000002 INTL 20100528)
12-56-59-224| [ KERNEL] [ 0.000719] ACPI: FACS 0x000000003FFF0200 000040
12-56-59-224| [ KERNEL] [ 0.000720] ACPI: FACS 0x000000003FFF0200 000040
12-56-59-224| [ KERNEL] [ 0.000722] ACPI: APIC 0x000000003FFF0240 000054 (v02 VBOX VBOXAPIC 00000001 ASL 00000061)
12-56-59-224| [ KERNEL] [ 0.000723] ACPI: SSDT 0x000000003FFF02A0 0001CC (v01 VBOX VBOXCPUT 00000002 INTL 20100528)
12-56-59-224| [ KERNEL] [ 0.000725] ACPI: Reserving FACP table memory at [mem 0x3fff00f0-0x3fff01e3]
12-56-59-224| [ KERNEL] [ 0.000726] ACPI: Reserving DSDT table memory at [mem 0x3fff0470-0x3fff2794]
12-56-59-224| [ KERNEL] [ 0.000727] ACPI: Reserving FACS table memory at [mem 0x3fff0200-0x3fff023f]
12-56-59-224| [ KERNEL] [ 0.000728] ACPI: Reserving APIC table memory at [mem 0x3fff0240-0x3fff0293]
12-56-59-224| [ KERNEL] [ 0.000728] ACPI: Reserving SSDT table memory at [mem 0x3fff02a0-0x3fff046b]
12-56-59-224| [ KERNEL] [ 0.000733] ACPI: Local APIC address 0xfee00000
12-56-59-224| [ KERNEL] [ 0.000742] 139MB HIGHMEM available.
12-56-59-224| [ KERNEL] [ 0.000743] 883MB LOWMEM available.
12-56-59-224| [ KERNEL] [ 0.000743] mapped low ram: 0 - 373fe000
12-56-59-224| [ KERNEL] [ 0.000744] low ram: 0 - 373fe000
12-56-59-224| [ KERNEL] [ 0.000745] Zone ranges:
12-56-59-224| [ KERNEL] [ 0.000745] DMA [mem 0x0000000000001000-0x0000000000ffffff]
12-56-59-224| [ KERNEL] [ 0.000746] Normal [mem 0x0000000001000000-0x00000000373fdfff]
12-56-59-224| [ KERNEL] [ 0.000747] HighMem [mem 0x00000000373fe000-0x000000003ffeffff]
12-56-59-224| [ KERNEL] [ 0.000747] Movable zone start for each node
12-56-59-224| [ KERNEL] [ 0.000747] Early memory node ranges
12-56-59-224| [ KERNEL] [ 0.000748] node 0: [mem 0x0000000000001000-0x000000000009efff]
12-56-59-224| [ KERNEL] [ 0.000749] node 0: [mem 0x0000000000100000-0x000000003ffeffff]
12-56-59-224| [ KERNEL] [ 0.000750] Initmem setup node 0 [mem 0x0000000000001000-0x000000003ffeffff]
12-56-59-224| [ KERNEL] [ 0.000750] On node 0 totalpages: 262030
12-56-59-224| [ KERNEL] [ 0.002169] DMA zone: 32 pages used for memmap
12-56-59-224| [ KERNEL] [ 0.002169] DMA zone: 0 pages reserved
12-56-59-224| [ KERNEL] [ 0.002170] DMA zone: 3998 pages, LIFO batch:0
12-56-59-224| [ KERNEL] [ 0.002206] Normal zone: 1736 pages used for memmap
12-56-59-224| [ KERNEL] [ 0.002207] Normal zone: 222206 pages, LIFO batch:63
12-56-59-224| [ KERNEL] [ 0.004107] HighMem zone: 35826 pages, LIFO batch:7
12-56-59-224| [ KERNEL] [ 0.004413] Using APIC driver default
12-56-59-224| [ KERNEL] [ 0.004654] ACPI: PM-Timer IO Port: 0x4008
12-56-59-224| [ KERNEL] [ 0.004655] ACPI: Local APIC address 0xfee00000
12-56-59-224| [ KERNEL] [ 0.004681] IOAPIC[0]: apic_id 1, version 32, address 0xfec00000, GSI 0-23
12-56-59-224| [ KERNEL] [ 0.004683] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
12-56-59-224| [ KERNEL] [ 0.004684] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 low level)
12-56-59-224| [ KERNEL] [ 0.004685] ACPI: IRQ0 used by override.
12-56-59-224| [ KERNEL] [ 0.004685] ACPI: IRQ9 used by override.
12-56-59-224| [ KERNEL] [ 0.004686] Using ACPI (MADT) for SMP configuration information
12-56-59-224| [ KERNEL] [ 0.004690] smpboot: Allowing 1 CPUs, 0 hotplug CPUs
12-56-59-224| [ KERNEL] [ 0.004695] [mem 0x40000000-0xfebfffff] available for PCI devices
12-56-59-224| [ KERNEL] [ 0.004696] Booting paravirtualized kernel on bare hardware
12-56-59-224| [ KERNEL] [ 0.004698] clocksource: refined-jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645519600211568 ns
12-56-59-224| [ KERNEL] [ 0.004701] setup_percpu: NR_CPUS:4 nr_cpumask_bits:4 nr_cpu_ids:1 nr_node_ids:1
12-56-59-224| [ KERNEL] [ 0.004711] percpu: Embedded 27 pages/cpu s79180 r0 d31412 u110592
12-56-59-224| [ KERNEL] [ 0.004713] pcpu-alloc: s79180 r0 d31412 u110592 alloc=27*4096
12-56-59-224| [ KERNEL] [ 0.004713] pcpu-alloc: [0] 0
12-56-59-224| [ KERNEL] [ 0.004719] Built 1 zonelists, mobility grouping on. Total pages: 260262
12-56-59-224| [ KERNEL] [ 0.004720] Kernel command line: BOOT_IMAGE=http://10.36.64.10:789/wtware/6.0.72/packages/kernel quiet
12-56-59-224| [ KERNEL] [ 0.004765] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
12-56-59-224| [ KERNEL] [ 0.004779] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
12-56-59-224| [ KERNEL] [ 0.004782] Initializing CPU#0
12-56-59-224| [ KERNEL] [ 0.004789] Initializing HighMem for node 0 (000373fe:0003fff0)
12-56-59-224| [ KERNEL] [ 0.007064] Initializing Movable for node 0 (00000000:00000000)
12-56-59-224| [ KERNEL] [ 0.007423] Memory: 1028644K/1048120K available (4710K kernel code, 221K rwdata, 1364K rodata, 3556K init, 304K bss, 19476K reserved, 0K cma-reserved, 143304K highmem)
12-56-59-224| [ KERNEL] [ 0.007426] virtual kernel memory layout:
12-56-59-224| [ KERNEL] [ 0.007426] fixmap : 0xfff65000 - 0xfffff000 ( 616 kB)
12-56-59-224| [ KERNEL] [ 0.007426] cpu_entry : 0xffc00000 - 0xffc9d000 ( 628 kB)
12-56-59-224| [ KERNEL] [ 0.007426] pkmap : 0xff400000 - 0xff800000 (4096 kB)
12-56-59-224| [ KERNEL] [ 0.007426] vmalloc : 0xf7bfe000 - 0xff3fe000 ( 120 MB)
12-56-59-224| [ KERNEL] [ 0.007426] lowmem : 0xc0000000 - 0xf73fe000 ( 883 MB)
12-56-59-224| [ KERNEL] [ 0.007426] .init : 0xc1635000 - 0xc19ae000 (3556 kB)
12-56-59-224| [ KERNEL] [ 0.007426] .data : 0xc1499ac5 - 0xc1629740 (1599 kB)
12-56-59-224| [ KERNEL] [ 0.007426] .text : 0xc1000000 - 0xc1499ac5 (4710 kB)
12-56-59-224| [ KERNEL] [ 0.007426] Checking if this processor honours the WP bit even in supervisor mode...Ok.
12-56-59-224| [ KERNEL] [ 0.007677] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
12-56-59-224| [ KERNEL] [ 0.007934] rcu: Hierarchical RCU implementation.
12-56-59-224| [ KERNEL] [ 0.007935] rcu: RCU restricting CPUs from NR_CPUS=4 to nr_cpu_ids=1.
12-56-59-224| [ KERNEL] [ 0.007936] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=1
12-56-59-224| [ KERNEL] [ 0.007945] NR_IRQS: 2304, nr_irqs: 256, preallocated irqs: 16
12-56-59-224| [ KERNEL] [ 0.008063] CPU 0 irqstacks, hard=(ptrval) soft=(ptrval)
12-56-59-224| [ KERNEL] [ 0.009994] Console: colour VGA+ 80x25
12-56-59-224| [ KERNEL] [ 0.010000] console [tty0] enabled
12-56-59-224| [ KERNEL] [ 0.010002] ACPI: Core revision 20180810
12-56-59-224| [ KERNEL] [ 0.010114] APIC: Switch to symmetric I/O mode setup
12-56-59-224| [ KERNEL] [ 0.010115] Enabling APIC mode: Flat. Using 1 I/O APICs
12-56-59-224| [ KERNEL] [ 0.010783] ..TIMER: vector=0x30 apic1=0 pin1=2 apic2=-1 pin2=-1
12-56-59-224| [ KERNEL] [ 0.030375] clocksource: tsc-early: mask: 0xffffffffffffffff max_cycles: 0x2f72f723c4f, max_idle_ns: 440795202126 ns
12-56-59-224| [ KERNEL] [ 0.030375] Calibrating delay loop (skipped), value calculated using timer frequency.. 6583.56 BogoMIPS (lpj=13167120)
12-56-59-224| [ KERNEL] [ 0.030375] pid_max: default: 32768 minimum: 301
12-56-59-224| [ KERNEL] [ 0.030375] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
12-56-59-224| [ KERNEL] [ 0.030375] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
12-56-59-224| [ KERNEL] [ 0.030375] Last level iTLB entries: 4KB 512, 2MB 512, 4MB 256
12-56-59-224| [ KERNEL] [ 0.030375] Last level dTLB entries: 4KB 2048, 2MB 2048, 4MB 1024, 1GB 0
12-56-59-224| [ KERNEL] [ 0.030375] Spectre V1 : Mitigation: usercopy/swapgs barriers and __user pointer sanitization
12-56-59-224| [ KERNEL] [ 0.030375] Spectre V2 : Spectre mitigation: kernel not compiled with retpoline; no mitigation available!
12-56-59-224| [ KERNEL] [ 0.030375] Speculative Store Bypass: Vulnerable
12-56-59-224| [ KERNEL] [ 0.032505] Freeing SMP alternatives memory: 20K
12-56-59-224| [ KERNEL] [ 0.140493] smpboot: CPU0: AMD Ryzen 5 5600H with Radeon Graphics (family: 0x19, model: 0x50, stepping: 0x0)
12-56-59-224| [ KERNEL] [ 0.140531] Performance Events: PMU not available due to virtualization, using software events only.
12-56-59-224| [ KERNEL] [ 0.140551] rcu: Hierarchical SRCU implementation.
12-56-59-224| [ KERNEL] [ 0.140678] smp: Bringing up secondary CPUs ...
12-56-59-224| [ KERNEL] [ 0.140679] smp: Brought up 1 node, 1 CPU
12-56-59-224| [ KERNEL] [ 0.140679] smpboot: Max logical packages: 1
12-56-59-224| [ KERNEL] [ 0.140680] smpboot: Total of 1 processors activated (6583.56 BogoMIPS)
12-56-59-224| [ KERNEL] [ 0.140779] devtmpfs: initialized
12-56-59-224| [ KERNEL] [ 0.140839] random: get_random_u32 called from bucket_table_alloc+0x80/0x160 with crng_init=0
12-56-59-224| [ KERNEL] [ 0.140874] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
12-56-59-224| [ KERNEL] [ 0.140876] futex hash table entries: 256 (order: 2, 16384 bytes)
12-56-59-224| [ KERNEL] [ 0.140884] pinctrl core: initialized pinctrl subsystem
12-56-59-224| [ KERNEL] [ 0.140918] NET: Registered protocol family 16
12-56-59-224| [ KERNEL] [ 0.140976] cpuidle: using governor ladder
12-56-59-224| [ KERNEL] [ 0.140976] cpuidle: using governor menu
12-56-59-224| [ KERNEL] [ 0.141144] ACPI: bus type PCI registered
12-56-59-224| [ KERNEL] [ 0.141346] PCI: PCI BIOS revision 2.10 entry at 0xfda26, last bus=0
12-56-59-224| [ KERNEL] [ 0.141347] PCI: Using configuration type 1 for base access
12-56-59-224| [ KERNEL] [ 0.141347] PCI: Using configuration type 1 for extended access
12-56-59-224| [ KERNEL] [ 0.142375] ACPI: Added _OSI(Module Device)
12-56-59-224| [ KERNEL] [ 0.142375] ACPI: Added _OSI(Processor Device)
12-56-59-224| [ KERNEL] [ 0.142375] ACPI: Added _OSI(3.0 _SCP Extensions)
12-56-59-224| [ KERNEL] [ 0.142375] ACPI: Added _OSI(Processor Aggregator Device)
12-56-59-224| [ KERNEL] [ 0.142375] ACPI: Added _OSI(Linux-Dell-Video)
12-56-59-224| [ KERNEL] [ 0.142375] ACPI: Added _OSI(Linux-Lenovo-NV-HDMI-Audio)
12-56-59-224| [ KERNEL] [ 0.142375] ACPI: 2 ACPI AML tables successfully acquired and loaded
12-56-59-224| [ KERNEL] [ 0.142375] ACPI: Interpreter enabled
12-56-59-224| [ KERNEL] [ 0.142375] ACPI: (supports S0 S5)
12-56-59-224| [ KERNEL] [ 0.142375] ACPI: Using IOAPIC for interrupt routing
12-56-59-224| [ KERNEL] [ 0.142375] PCI: Ignoring host bridge windows from ACPI; if necessary, use "pci=use_crs" and report a bug
12-56-59-224| [ KERNEL] [ 0.142375] ACPI: Enabled 2 GPEs in block 00 to 07
12-56-59-224| [ KERNEL] [ 0.143646] ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-ff])
12-56-59-224| [ KERNEL] [ 0.143649] acpi PNP0A03:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI]
12-56-59-224| [ KERNEL] [ 0.143931] acpi PNP0A03:00: _OSC: platform does not support [PCIeCapability LTR]
12-56-59-224| [ KERNEL] [ 0.144067] acpi PNP0A03:00: _OSC: not requesting control; platform does not support [PCIeCapability]
12-56-59-224| [ KERNEL] [ 0.144067] acpi PNP0A03:00: _OSC: OS requested [PME PCIeCapability LTR]
12-56-59-224| [ KERNEL] [ 0.144068] acpi PNP0A03:00: _OSC: platform willing to grant [PME]
12-56-59-224| [ KERNEL] [ 0.144069] acpi PNP0A03:00: _OSC failed (AE_SUPPORT); disabling ASPM
12-56-59-224| [ KERNEL] [ 0.144117] acpi PNP0A03:00: host bridge window [io 0x0cf8-0x0cff] (ignored)
12-56-59-224| [ KERNEL] [ 0.144118] acpi PNP0A03:00: host bridge window [io 0x0000-0x0cf7 window] (ignored)
12-56-59-224| [ KERNEL] [ 0.144119] acpi PNP0A03:00: host bridge window [io 0x0d00-0xffff window] (ignored)
12-56-59-224| [ KERNEL] [ 0.144119] acpi PNP0A03:00: host bridge window [mem 0x000a0000-0x000bffff window] (ignored)
12-56-59-224| [ KERNEL] [ 0.144120] acpi PNP0A03:00: host bridge window [mem 0x40000000-0xfdffffff window] (ignored)
12-56-59-224| [ KERNEL] [ 0.144120] PCI: root bus 00: using default resources
12-56-59-224| [ KERNEL] [ 0.144131] PCI host bridge to bus 0000:00
12-56-59-224| [ KERNEL] [ 0.144132] pci_bus 0000:00: root bus resource [io 0x0000-0xffff]
12-56-59-224| [ KERNEL] [ 0.144133] pci_bus 0000:00: root bus resource [mem 0x00000000-0xffffffff]
12-56-59-224| [ KERNEL] [ 0.144134] pci_bus 0000:00: root bus resource [bus 00-ff]
12-56-59-224| [ KERNEL] [ 0.144158] pci 0000:00:00.0: [8086:1237] type 00 class 0x060000
12-56-59-224| [ KERNEL] [ 0.144563] pci 0000:00:01.0: [8086:7000] type 00 class 0x060100
12-56-59-224| [ KERNEL] [ 0.144961] pci 0000:00:02.0: [80ee:beef] type 00 class 0x030000
12-56-59-224| [ KERNEL] [ 0.145443] pci 0000:00:02.0: reg 0x10: [mem 0xe0000000-0xe1ffffff pref]
12-56-59-224| [ KERNEL] [ 0.145737] pci 0000:00:02.0: reg 0x14: [io 0xd000-0xd00f]
12-56-59-224| [ KERNEL] [ 0.145973] pci 0000:00:02.0: reg 0x18: [mem 0xf0000000-0xf01fffff]
12-56-59-224| [ KERNEL] [ 0.147150] pci 0000:00:03.0: [8086:100e] type 00 class 0x020000
12-56-59-224| [ KERNEL] [ 0.147317] pci 0000:00:03.0: reg 0x10: [mem 0xf0200000-0xf021ffff]
12-56-59-224| [ KERNEL] [ 0.147529] pci 0000:00:03.0: reg 0x18: [io 0xd010-0xd017]
12-56-59-224| [ KERNEL] [ 0.148197] pci 0000:00:04.0: [80ee:cafe] type 00 class 0x088000
12-56-59-224| [ KERNEL] [ 0.148338] pci 0000:00:04.0: reg 0x10: [io 0xd020-0xd03f]
12-56-59-224| [ KERNEL] [ 0.148444] pci 0000:00:04.0: reg 0x14: [mem 0xf0400000-0xf07fffff]
12-56-59-224| [ KERNEL] [ 0.148548] pci 0000:00:04.0: reg 0x18: [mem 0xf0800000-0xf0803fff pref]
12-56-59-224| [ KERNEL] [ 0.149107] pci 0000:00:05.0: [8086:2668] type 00 class 0x040300
12-56-59-224| [ KERNEL] [ 0.149257] pci 0000:00:05.0: reg 0x10: [mem 0xf0804000-0xf0807fff]
12-56-59-224| [ KERNEL] [ 0.150101] pci 0000:00:06.0: [106b:003f] type 00 class 0x0c0310
12-56-59-224| [ KERNEL] [ 0.150246] pci 0000:00:06.0: reg 0x10: [mem 0xf0808000-0xf0808fff]
12-56-59-224| [ KERNEL] [ 0.150993] pci 0000:00:07.0: [8086:7113] type 00 class 0x068000
12-56-59-224| [ KERNEL] [ 0.151279] pci 0000:00:07.0: quirk: [io 0x4000-0x403f] claimed by PIIX4 ACPI
12-56-59-224| [ KERNEL] [ 0.151285] pci 0000:00:07.0: quirk: [io 0x4100-0x410f] claimed by PIIX4 SMB
12-56-59-224| [ KERNEL] [ 0.151449] pci 0000:00:0b.0: [8086:265c] type 00 class 0x0c0320
12-56-59-224| [ KERNEL] [ 0.151594] pci 0000:00:0b.0: reg 0x10: [mem 0xf0809000-0xf0809fff]
12-56-59-224| [ KERNEL] [ 0.152395] pci 0000:00:0d.0: [8086:2829] type 00 class 0x010601
12-56-59-224| [ KERNEL] [ 0.152550] pci 0000:00:0d.0: reg 0x10: [io 0xd040-0xd047]
12-56-59-224| [ KERNEL] [ 0.152654] pci 0000:00:0d.0: reg 0x14: [io 0xd048-0xd04b]
12-56-59-224| [ KERNEL] [ 0.152760] pci 0000:00:0d.0: reg 0x18: [io 0xd050-0xd057]
12-56-59-224| [ KERNEL] [ 0.152864] pci 0000:00:0d.0: reg 0x1c: [io 0xd058-0xd05b]
12-56-59-224| [ KERNEL] [ 0.152968] pci 0000:00:0d.0: reg 0x20: [io 0xd060-0xd06f]
12-56-59-224| [ KERNEL] [ 0.153072] pci 0000:00:0d.0: reg 0x24: [mem 0xf080a000-0xf080bfff]
12-56-59-224| [ KERNEL] [ 0.153444] pci_bus 0000:00: on NUMA node 0
12-56-59-224| [ KERNEL] [ 0.153930] ACPI: PCI Interrupt Link [LNKA] (IRQs 5 9 10 *11)
12-56-59-224| [ KERNEL] [ 0.154028] ACPI: PCI Interrupt Link [LNKB] (IRQs 5 9 *10 11)
12-56-59-224| [ KERNEL] [ 0.154068] ACPI: PCI Interrupt Link [LNKC] (IRQs 5 *9 10 11)
12-56-59-224| [ KERNEL] [ 0.154107] ACPI: PCI Interrupt Link [LNKD] (IRQs 5 9 10 *11)
12-56-59-224| [ KERNEL] [ 0.154192] pci 0000:00:02.0: vgaarb: setting as boot VGA device
12-56-59-224| [ KERNEL] [ 0.154193] pci 0000:00:02.0: vgaarb: VGA device added: decodes=io+mem,owns=io+mem,locks=none
12-56-59-224| [ KERNEL] [ 0.154194] pci 0000:00:02.0: vgaarb: bridge control possible
12-56-59-224| [ KERNEL] [ 0.154195] vgaarb: loaded
12-56-59-224| [ KERNEL] [ 0.154210] ACPI: bus type USB registered
12-56-59-224| [ KERNEL] [ 0.154221] usbcore: registered new interface driver usbfs
12-56-59-224| [ KERNEL] [ 0.154226] usbcore: registered new interface driver hub
12-56-59-224| [ KERNEL] [ 0.154230] usbcore: registered new device driver usb
12-56-59-224| [ KERNEL] [ 0.154250] pps_core: LinuxPPS API ver. 1 registered
12-56-59-224| [ KERNEL] [ 0.154250] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
12-56-59-224| [ KERNEL] [ 0.154253] PTP clock support registered
12-56-59-224| [ KERNEL] [ 0.154271] PCI: Using ACPI for IRQ routing
12-56-59-224| [ KERNEL] [ 0.154271] PCI: pci_cache_line_size set to 64 bytes
12-56-59-224| [ KERNEL] [ 0.154448] e820: reserve RAM buffer [mem 0x0009fc00-0x0009ffff]
12-56-59-224| [ KERNEL] [ 0.154449] e820: reserve RAM buffer [mem 0x3fff0000-0x3fffffff]
12-56-59-224| [ KERNEL] [ 0.154614] clocksource: Switched to clocksource tsc-early
12-56-59-224| [ KERNEL] [ 0.154629] pnp: PnP ACPI init
12-56-59-224| [ KERNEL] [ 0.154654] pnp 00:00: Plug and Play ACPI device, IDs PNP0303 (active)
12-56-59-224| [ KERNEL] [ 0.154685] pnp 00:01: Plug and Play ACPI device, IDs PNP0f03 (active)
12-56-59-224| [ KERNEL] [ 0.154991] pnp: PnP ACPI: found 2 devices
12-56-59-224| [ KERNEL] [ 0.189825] clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
12-56-59-224| [ KERNEL] [ 0.190135] pci_bus 0000:00: resource 4 [io 0x0000-0xffff]
12-56-59-224| [ KERNEL] [ 0.190136] pci_bus 0000:00: resource 5 [mem 0x00000000-0xffffffff]
12-56-59-224| [ KERNEL] [ 0.190156] NET: Registered protocol family 2
12-56-59-224| [ KERNEL] [ 0.190163] IP idents hash table entries: 16384 (order: 5, 131072 bytes)
12-56-59-224| [ KERNEL] [ 0.190163] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes)
12-56-59-224| [ KERNEL] [ 0.190163] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
12-56-59-224| [ KERNEL] [ 0.190163] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
12-56-59-224| [ KERNEL] [ 0.190163] TCP: Hash tables configured (established 8192 bind 8192)
12-56-59-224| [ KERNEL] [ 0.190163] UDP hash table entries: 512 (order: 2, 16384 bytes)
12-56-59-224| [ KERNEL] [ 0.190163] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
12-56-59-224| [ KERNEL] [ 0.190163] NET: Registered protocol family 1
12-56-59-224| [ KERNEL] [ 0.190288] pci 0000:00:00.0: Limiting direct PCI/PCI transfers
12-56-59-224| [ KERNEL] [ 0.190288] pci 0000:00:01.0: Activating ISA DMA hang workarounds
12-56-59-224| [ KERNEL] [ 0.190288] pci 0000:00:02.0: Video device with shadowed ROM at [mem 0x000c0000-0x000dffff]
12-56-59-224| [ KERNEL] [ 0.191113] PCI: CLS 0 bytes, default 64
12-56-59-224| [ KERNEL] [ 0.400285] platform rtc_cmos: registered platform RTC device (no PNP device found)
12-56-59-224| [ KERNEL] [ 0.400425] Initialise system trusted keyrings
12-56-59-224| [ KERNEL] [ 0.401610] workingset: timestamp_bits=30 max_order=18 bucket_order=0
12-56-59-224| [ KERNEL] [ 0.410831] Key type asymmetric registered
12-56-59-224| [ KERNEL] [ 0.410832] Asymmetric key parser 'x509' registered
12-56-59-224| [ KERNEL] [ 0.410836] bounce: pool size: 64 pages
12-56-59-224| [ KERNEL] [ 0.410841] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 250)
12-56-59-224| [ KERNEL] [ 0.410842] io scheduler noop registered
12-56-59-224| [ KERNEL] [ 0.410843] io scheduler deadline registered (default)
12-56-59-224| [ KERNEL] [ 0.410848] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input0
12-56-59-224| [ KERNEL] [ 0.410848] ACPI: Power Button [PWRF]
12-56-59-224| [ KERNEL] [ 0.411390] input: Sleep Button as /devices/LNXSYSTM:00/LNXSLPBN:00/input/input1
12-56-59-224| [ KERNEL] [ 0.411423] ACPI: Sleep Button [SLPF]
12-56-59-224| [ KERNEL] [ 0.411507] ACPI: Video Device [GFX0] (multi-head: yes rom: no post: no)
12-56-59-224| [ KERNEL] [ 0.411560] input: Video Bus as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A03:00/LNXVIDEO:00/input/input2
12-56-59-224| [ KERNEL] [ 0.414157] Linux agpgart interface v0.103
12-56-59-224| [ KERNEL] [ 0.414303] zram: Added device: zram0
12-56-59-224| [ KERNEL] [ 0.414366] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
12-56-59-224| [ KERNEL] [ 0.414367] ehci-pci: EHCI PCI platform driver
12-56-59-224| [ KERNEL] [ 0.414626] ehci-pci 0000:00:0b.0: EHCI Host Controller
12-56-59-224| [ KERNEL] [ 0.414629] ehci-pci 0000:00:0b.0: new USB bus registered, assigned bus number 1
12-56-59-224| [ KERNEL] [ 0.414788] ehci-pci 0000:00:0b.0: irq 19, io mem 0xf0809000
12-56-59-224| [ KERNEL] [ 0.431221] ehci-pci 0000:00:0b.0: USB 2.0 started, EHCI 1.00
12-56-59-224| [ KERNEL] [ 0.431375] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 4.19
12-56-59-224| [ KERNEL] [ 0.431379] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
12-56-59-224| [ KERNEL] [ 0.431383] usb usb1: Product: EHCI Host Controller
12-56-59-224| [ KERNEL] [ 0.431387] usb usb1: Manufacturer: Linux 4.19.225 ehci_hcd
12-56-59-224| [ KERNEL] [ 0.431390] usb usb1: SerialNumber: 0000:00:0b.0
12-56-59-224| [ KERNEL] [ 0.431510] hub 1-0:1.0: USB hub found
12-56-59-224| [ KERNEL] [ 0.431534] hub 1-0:1.0: 12 ports detected
12-56-59-224| [ KERNEL] [ 0.431696] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
12-56-59-224| [ KERNEL] [ 0.431697] ohci-pci: OHCI PCI platform driver
12-56-59-224| [ KERNEL] [ 0.432118] ohci-pci 0000:00:06.0: OHCI PCI host controller
12-56-59-224| [ KERNEL] [ 0.432122] ohci-pci 0000:00:06.0: new USB bus registered, assigned bus number 2
12-56-59-224| [ KERNEL] [ 0.432174] ohci-pci 0000:00:06.0: irq 22, io mem 0xf0808000
12-56-59-224| [ KERNEL] [ 0.491554] usb usb2: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 4.19
12-56-59-224| [ KERNEL] [ 0.491561] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
12-56-59-224| [ KERNEL] [ 0.491568] usb usb2: Product: OHCI PCI host controller
12-56-59-224| [ KERNEL] [ 0.491574] usb usb2: Manufacturer: Linux 4.19.225 ohci_hcd
12-56-59-224| [ KERNEL] [ 0.491579] usb usb2: SerialNumber: 0000:00:06.0
12-56-59-224| [ KERNEL] [ 0.491700] hub 2-0:1.0: USB hub found
12-56-59-224| [ KERNEL] [ 0.491729] hub 2-0:1.0: 12 ports detected
12-56-59-224| [ KERNEL] [ 0.492005] uhci_hcd: USB Universal Host Controller Interface driver
12-56-59-224| [ KERNEL] [ 0.492049] i8042: PNP: PS/2 Controller [PNP0303:PS2K,PNP0f03:PS2M] at 0x60,0x64 irq 1,12
12-56-59-224| [ KERNEL] [ 0.492428] serio: i8042 KBD port at 0x60,0x64 irq 1
12-56-59-224| [ KERNEL] [ 0.492446] serio: i8042 AUX port at 0x60,0x64 irq 12
12-56-59-224| [ KERNEL] [ 0.492463] hv_vmbus: registering driver hyperv_keyboard
12-56-59-224| [ KERNEL] [ 0.492666] input: AT Translated Set 2 keyboard as /devices/platform/i8042/serio0/input/input3
12-56-59-224| [ KERNEL] [ 0.492746] usbcore: registered new interface driver synaptics_usb
12-56-59-224| [ KERNEL] [ 0.492768] usbcore: registered new interface driver usbtouchscreen
12-56-59-224| [ KERNEL] [ 0.492787] input: PC Speaker as /devices/platform/pcspkr/input/input4
12-56-59-224| [ KERNEL] [ 0.493661] rtc_cmos rtc_cmos: registered as rtc0
12-56-59-224| [ KERNEL] [ 0.493672] rtc_cmos rtc_cmos: alarms up to one day, 114 bytes nvram
12-56-59-224| [ KERNEL] [ 0.493717] cpufreq_nforce2: No nForce2 chipset
12-56-59-224| [ KERNEL] [ 0.493732] hidraw: raw HID events driver (C) Jiri Kosina
12-56-59-224| [ KERNEL] [ 0.493774] hv_vmbus: registering driver hid_hyperv
12-56-59-224| [ KERNEL] [ 0.493871] usbcore: registered new interface driver usbhid
12-56-59-224| [ KERNEL] [ 0.493871] usbhid: USB HID core driver
12-56-59-224| [ KERNEL] [ 0.493919] NET: Registered protocol family 17
12-56-59-224| [ KERNEL] [ 0.493956] mce: Using 0 MCE banks
12-56-59-224| [ KERNEL] [ 0.493959] Using IPI No-Shortcut mode
12-56-59-224| [ KERNEL] [ 0.493962] sched_clock: Marking stable (488088096, 2293300)->(493300932, -2919536)
12-56-59-224| [ KERNEL] [ 0.494011] Loading compiled-in X.509 certificates
12-56-59-224| [ KERNEL] [ 0.503273] rtc_cmos rtc_cmos: setting system clock to 2022-04-29 12:43:58 UTC (1651236238)
12-56-59-224| [ KERNEL] [ 0.503689] Freeing unused kernel image memory: 3556K
12-56-59-224| [ KERNEL] [ 0.510178] Write protecting the kernel text: 4712k
12-56-59-224| [ KERNEL] [ 0.510185] Write protecting the kernel read-only data: 1376k
12-56-59-224| [ KERNEL] [ 0.510186] Run /init as init process
12-56-59-224| [ KERNEL] [ 0.696711] input: ImExPS/2 Generic Explorer Mouse as /devices/platform/i8042/serio1/input/input6
12-56-59-224| [ hotplug] [ 0.717025] Block device 254:0. No action.
12-56-59-224| [ pfac] [ 0.817062] Run /sbin/initrd.
12-56-59-224| [ pfac] [ 0.817094] Ok, PID 669.
12-56-59-224| [ initrd] [ 0.817611] WTware 6.0.72 shell.
12-56-59-224| [ initrd] [ 0.827682] HTTP: IP 10.36.64.10, port 789, path '/wtware/', slash '/'.
12-56-59-224| [ initrd] [ 0.830812] Load Ethernet drivers.
12-56-59-224| [ initrd] [ 0.831505] modprobe e1000.
12-56-59-224| [ KERNEL] [ 0.834730] e1000: Intel(R) PRO/1000 Network Driver - version 7.3.21-k8-NAPI
12-56-59-224| [ KERNEL] [ 0.834730] e1000: Copyright (c) 1999-2006 Intel Corporation.
12-56-59-224| [ KERNEL] [ 0.842639] usb 2-1: new full-speed USB device number 2 using ohci-pci
12-56-59-224| [ KERNEL] [ 1.166824] usb 2-1: New USB device found, idVendor=80ee, idProduct=0021, bcdDevice= 1.00
12-56-59-224| [ KERNEL] [ 1.166825] usb 2-1: New USB device strings: Mfr=1, Product=3, SerialNumber=0
12-56-59-224| [ KERNEL] [ 1.166826] usb 2-1: Product: USB Tablet
12-56-59-224| [ KERNEL] [ 1.166827] usb 2-1: Manufacturer: VirtualBox
12-56-59-224| [ initrd] [ 1.167302] NIC module e1000.ko loaded.
12-56-59-224| [ KERNEL] [ 1.169251] e1000 0000:00:03.0 eth0: (PCI:33MHz:32-bit) 08:00:27:24:0e:28
12-56-59-224| [ KERNEL] [ 1.169253] e1000 0000:00:03.0 eth0: Intel(R) PRO/1000 Network Connection
12-56-59-224| [ initrd] [ 1.172536] eth0: 8086:100e. Apply WOL configuration.
12-56-59-224| [ initrd] [ 1.172749] Failed to write WOL settings.
12-56-59-224| [ KERNEL] [ 1.186895] input: VirtualBox USB Tablet as /devices/pci0000:00/0000:00:06.0/usb2/2-1/2-1:1.0/0003:80EE:0021.0001/input/input7
12-56-59-224| [ KERNEL] [ 1.187299] hid-generic 0003:80EE:0021.0001: input,hidraw0: USB HID v1.10 Mouse [VirtualBox USB Tablet] on usb-0000:00:06.0-1/input0
12-56-59-224| [ KERNEL] [ 1.418426] tsc: Refined TSC clocksource calibration: 3293.802 MHz
12-56-59-224| [ KERNEL] [ 1.418430] clocksource: tsc: mask: 0xffffffffffffffff max_cycles: 0x2f7a6d49d86, max_idle_ns: 440795363309 ns
12-56-59-224| [ KERNEL] [ 1.418437] clocksource: Switched to clocksource tsc
12-56-59-224| [ KERNEL] [ 3.211304] e1000: eth0 NIC Link is Up 1000 Mbps Full Duplex, Flow Control: RX
12-56-59-224| [ initrd] [ 4.178083] dhcp: 363 bytes from 10.36.64.10.
12-56-59-224| [ initrd] [ 4.178110] 00000000:0000015700000000001100000A24400AFFFFFFFF004300440157000002010600 ...W........$@......C.D.W......
12-56-59-224| [ initrd] [ 4.178121] 00000020:67458B6B00000000000000000A2440270A24400A00000000080027240E280000 gE.k.........$@'.$@.......'$.(..
12-56-59-224| [ initrd] [ 4.178133] 00000040:0000000000000000000000000000000000000000000000000000000000000000 ................................
12-56-59-224| [ initrd] [ 4.178141] 00000060:0000000000000000000000000000000000000000000000000000000000000000 ................................
12-56-59-224| [ initrd] [ 4.178150] 00000080:0000000000000000362E302E37322F7774776172652E68747470000000000000 ........6.0.72/wtware.http......
12-56-59-224| [ initrd] [ 4.178159] 000000a0:0000000000000000000000000000000000000000000000000000000000000000 ................................
12-56-59-224| [ initrd] [ 4.178167] 000000c0:0000000000000000000000000000000000000000000000000000000000000000 ................................
12-56-59-224| [ initrd] [ 4.178176] 000000e0:0000000000000000000000000000000000000000000000000000000000000000 ................................
12-56-59-224| [ initrd] [ 4.178184] 00000100:0000000000000000638253633501020104FFFFFF003A04000546003B0400093A ........c.Sc5........:...F.;...:
12-56-59-224| [ initrd] [ 4.178192] 00000120:803304000A8C0036040A24400A03040A24400106040A24400A0F0C76726E7A64 .3.....6..$@....$@....$@...vrnzd
12-56-59-224| [ initrd] [ 5.182360] dhcp: 363 bytes from 10.36.64.10.
12-56-59-224| [ initrd] [ 5.182383] 00000000:0000015700000000001100000A24400AFFFFFFFF004300440157000002010600 ...W........$@......C.D.W......
12-56-59-224| [ initrd] [ 5.182432] 00000020:67458B6B00000000000000000A2440270A24400A00000000080027240E280000 gE.k.........$@'.$@.......'$.(..
12-56-59-224| [ initrd] [ 5.182440] 00000040:0000000000000000000000000000000000000000000000000000000000000000 ................................
12-56-59-224| [ initrd] [ 5.182448] 00000060:0000000000000000000000000000000000000000000000000000000000000000 ................................
12-56-59-224| [ initrd] [ 5.182455] 00000080:0000000000000000362E302E37322F7774776172652E68747470000000000000 ........6.0.72/wtware.http......
12-56-59-224| [ initrd] [ 5.182463] 000000a0:0000000000000000000000000000000000000000000000000000000000000000 ................................
12-56-59-224| [ initrd] [ 5.182470] 000000c0:0000000000000000000000000000000000000000000000000000000000000000 ................................
12-56-59-224| [ initrd] [ 5.182479] 000000e0:0000000000000000000000000000000000000000000000000000000000000000 ................................
12-56-59-224| [ initrd] [ 5.182493] 00000100:0000000000000000638253633501053A04000546003B0400093A803304000A8C ........c.Sc5..:...F.;...:.3....
12-56-59-224| [ initrd] [ 5.182502] 00000120:0036040A24400A0104FFFFFF0003040A24400106040A24400A0F0C76726E7A64 .6..$@..........$@....$@...vrnzd
12-56-59-224| [ initrd] [ 5.182511] [DHCP] DHCP server address 10.36.64.10.
12-56-59-224| [ initrd] [ 5.182522] [DHCP] IP 10.36.64.39 mask 255.255.255.0.
12-56-59-224| [ initrd] [ 5.182532] [DHCP] Default gateway 10.36.64.1.
12-56-59-224| [ initrd] [ 5.182541] [DHCP] DNS 10.36.64.10.
12-56-59-224| [ initrd] [ 5.182550] [DHCP] Domain vrnzdrav.ru.
12-56-59-224| [ initrd] [ 5.182559] [DHCP] HTTP IP 10.36.64.10 already specified.
12-56-59-224| WTC listener is active.
12-56-59-224| WTC broadcast listener is active.
12-56-59-224| Send broadcast WTCU discover.
12-56-59-224| [ initrd] [ 5.182849] [HTTP] Download and unpack file /wtware/6.0.72/packages/lib6 from 10.36.64.10.
12-56-59-224| [ KERNEL] [ 5.190882] random: fast init done
12-56-59-224| [ initrd] [ 5.534386] PCI: C 06 8086:1237 Bridge Intel Corporation 440FX - 82441FX PMC [Natoma].
12-56-59-224| [ initrd] [ 5.534405] PCI: C 02 8086:100e Network controller Intel Corporation 82540EM Gigabit Ethernet Controller.
12-56-59-224| [ initrd] [ 5.534416] PCI: C 0c:03 106b:003f Serial bus controller USB controller Apple Inc. KeyLargo/Intrepid USB.
12-56-59-224| [ initrd] [ 5.534425] PCI: C 0c:03 8086:265c Serial bus controller USB controller Intel Corporation 82801FB/FBM/FR/FW/FRW (ICH6 Family) USB2 EHCI Controller.
12-56-59-224| [ initrd] [ 5.534434] PCI: C 03 80ee:beef Display controller InnoTek Systemberatung GmbH VirtualBox Graphics Adapter.
12-56-59-224| [ initrd] [ 5.534442] PCI: C 04:03 8086:2668 Multimedia controller Audio device Intel Corporation 82801FB/FBM/FR/FW/FRW (ICH6 Family) High Definition Audio Contr.
12-56-59-224| [ initrd] [ 5.534453] PCI: C 01:06 8086:2829 Mass storage controller SATA controller Intel Corporation 82801HM/HEM (ICH8M/ICH8M-E) SATA Controller [AHCI mode].
12-56-59-224| [ initrd] [ 5.534461] PCI: C 06:01 8086:7000 Bridge ISA bridge Intel Corporation 82371SB PIIX3 ISA [Natoma/Triton II].
12-56-59-224| [ initrd] [ 5.534470] PCI: C 08:80 80ee:cafe Generic system peripheral System peripheral InnoTek Systemberatung GmbH VirtualBox Guest Service.
12-56-59-224| [ initrd] [ 5.534478] PCI: C 06:80 8086:7113 Bridge Bridge Intel Corporation 82371AB/EB/MB PIIX4 ACPI.
12-56-59-224| [ initrd] [ 5.539250] USB: 80ee:0021 VirtualBox USB Tablet.
12-56-59-224| [ initrd] [ 5.541577] Run '/sbin/httpd', log '/tmp/httpd.out', env '', pid ''.
12-56-59-224| [ pfac] [ 5.541822] Run /sbin/httpd.
12-56-59-224| [ pfac] [ 5.541842] Ok, PID 691.
12-56-59-224| [ initrd] [ 5.541893] [HTTP] Download config file /wtware/Everyone/source.wtc from 10.36.64.10.
12-56-59-224| [ httpd] [ 5.542998] Internal HTTP Server, WTware 6.0.72
12-56-59-224| [ initrd] [ 5.543541] [HTTP] Download config file /wtware/Everyone/list.wtc from 10.36.64.10.
12-56-59-224| [ initrd] [ 5.544706] [HTTP] Download config file /wtware/Terminals/08.00.27.24.0E.28/config.wtc from 10.36.64.10.
12-56-59-224| [ initrd] [ 5.545577] [HTTP] Download config file /wtware/Terminals/08.00.27.24.0E.28/wtware.lic from 10.36.64.10.
12-56-59-224| [ initrd] [ 5.546358] [HTTP] File not found.
12-56-59-224| /--- FILE "/tmp/config.wtc" -----------------------
12-56-59-224| | server=10.36.64.11; 10.36.64.12
12-56-59-224| | infobox=always, shutdown, reboot
12-56-59-224| | connection
12-56-59-224| \----------------------------------------------------
12-56-59-224| [ initrd] [ 5.546562] [HTTP] Download config file /wtware/Everyone/all.wtc from 10.36.64.10.
12-56-59-224| /--- FILE "/tmp/all.wtc" -----------------------
12-56-59-224| | [BOM]
12-56-59-224| | server=10.36.64.12
12-56-59-224| [ initrd] [ 5.547332] [HTTP] Download config file /wtware/Everyone/wtware.lic from 10.36.64.10.
12-56-59-224| /--- FILE "/etc/config.compiled" -----------------------
12-56-59-224| [ initrd] [ 5.548789] Hostname: "wtw080027240E28".
12-56-59-224| [ initrd] [ 5.548797] [NTP] 42 DHCP option is not set.
12-56-59-224| Everyone can control terminal by RSH.
12-56-59-224| RSH: listener is active.
12-56-59-224| [ initrd] [ 5.548955] Use 'video=VESA(F)' driver.
12-56-59-224| | video=VESA(F)
12-56-59-224| [ initrd] [ 5.549012] [HTTP] Download and unpack file /wtware/6.0.72/packages/f-drm from 10.36.64.10.
12-56-59-224| [ httpd] [ 5.549056] Reread settings.
12-56-59-224| [ httpd] [ 5.549117] Everyone can control terminal by HTTP.
12-56-59-224| [ initrd] [ 5.576425] [HTTP] Download and unpack file /wtware/6.0.72/packages/fwt6 from 10.36.64.10.
12-56-59-224| [ initrd] [ 5.687717] [HTTP] Download and unpack file /wtware/6.0.72/packages/f from 10.36.64.10.
12-56-59-224| [ KERNEL] [ 5.705831] random: crng init done
12-56-59-224| [ initrd] [ 5.722497] [HTTP] Download and unpack file /wtware/6.0.72/packages/graphic from 10.36.64.10.
12-56-59-224| [ gm] [ 5.737060] WTware 6.0.72 session manager.
12-56-59-224| [ gm] [ 5.797610] [EVDEV] EV_REL flag found. Add event6: VirtualBox USB Tablet.
12-56-59-224| [ gm] [ 5.797650] [EVDEV] EV_REL flag found. Add event5: ImExPS/2 Generic Explorer Mouse.
12-56-59-224| [ gm] [ 5.797675] [EVDEV] Ignore event4: PC Speaker.
12-56-59-224| [ gm] [ 5.797698] [EVDEV] Keys found. Add event3: AT Translated Set 2 keyboard.
12-56-59-224| [ gm] [ 5.797722] [EVDEV] Keys found. Add event2: Video Bus.
12-56-59-224| [ gm] [ 5.797743] [EVDEV] Keys found. Add event1: Sleep Button.
12-56-59-224| [ gm] [ 5.797765] [EVDEV] Keys found. Add event0: Power Button.
12-56-59-224| [ gm] [ 5.797804] Display mode: 1024x768, 32 bit, landscape, 0 Hz, modeline "", DDC enabled, connector 0.
12-56-59-224| [ gm] [ 5.958881] VBE Version 2.0.
12-56-59-224| [ gm] [ 5.958997] VBE modelist at 0x00011032.
12-56-59-224| [ gm] [ 5.959584] Mode 256: 640x400 (256 color palette) linelength 640 bits 8.
12-56-59-224| [ gm] [ 5.960155] Mode 257: 640x480 (256 color palette) linelength 640 bits 8.
12-56-59-224| [ gm] [ 5.961244] Mode 259: 800x600 (256 color palette) linelength 800 bits 8.
12-56-59-224| [ gm] [ 5.962372] Mode 261: 1024x768 (256 color palette) linelength 1024 bits 8.
12-56-59-224| [ gm] [ 5.963556] Mode 263: 1280x1024 (256 color palette) linelength 1280 bits 8.
12-56-59-224| [ gm] [ 5.964181] Mode 269: 320x200 (5:5:5) linelength 640 bits 15.
12-56-59-224| [ gm] [ 5.964814] Mode 270: 320x200 (5:6:5) linelength 640 bits 16.
12-56-59-224| [ gm] [ 5.965456] Mode 271: 320x200 (8:8:8) linelength 960 bits 24.
12-56-59-224| [ gm] [ 5.966177] Mode 272: 640x480 (5:5:5) linelength 1280 bits 15.
12-56-59-224| [ gm] [ 5.966854] Mode 273: 640x480 (5:6:5) linelength 1280 bits 16.
12-56-59-224| [ gm] [ 5.967543] Mode 274: 640x480 (8:8:8) linelength 1920 bits 24.
12-56-59-224| [ gm] [ 5.968251] Mode 275: 800x600 (5:5:5) linelength 1600 bits 15.
12-56-59-224| [ gm] [ 5.968967] Mode 276: 800x600 (5:6:5) linelength 1600 bits 16.
12-56-59-224| [ gm] [ 5.969696] Mode 277: 800x600 (8:8:8) linelength 2400 bits 24.
12-56-59-224| [ gm] [ 5.970439] Mode 278: 1024x768 (5:5:5) linelength 2048 bits 15.
12-56-59-224| [ gm] [ 5.971193] Mode 279: 1024x768 (5:6:5) linelength 2048 bits 16.
12-56-59-224| [ gm] [ 5.971981] Mode 280: 1024x768 (8:8:8) linelength 3072 bits 24.
12-56-59-224| [ gm] [ 5.972770] Mode 281: 1280x1024 (5:5:5) linelength 2560 bits 15.
12-56-59-224| [ gm] [ 5.973570] Mode 282: 1280x1024 (5:6:5) linelength 2560 bits 16.
12-56-59-224| [ gm] [ 5.974382] Mode 283: 1280x1024 (8:8:8) linelength 3840 bits 24.
12-56-59-224| [ gm] [ 5.975207] Mode 320: 320x200 (8:8:8) linelength 1280 bits 32.
12-56-59-224| [ gm] [ 5.976046] Mode 321: 640x400 (8:8:8) linelength 2560 bits 32.
12-56-59-224| [ gm] [ 5.976909] Mode 322: 640x480 (8:8:8) linelength 2560 bits 32.
12-56-59-224| [ gm] [ 5.977779] Mode 323: 800x600 (8:8:8) linelength 3200 bits 32.
12-56-59-224| [ gm] [ 5.978664] Mode 324: 1024x768 (8:8:8) linelength 4096 bits 32.
12-56-59-224| [ gm] [ 5.978673] Use mode 324.
12-56-59-224| [ gm] [ 5.979569] Mode 325: 1280x1024 (8:8:8) linelength 5120 bits 32.
12-56-59-224| [ gm] [ 5.980511] Mode 326: 320x200 (256 color palette) linelength 320 bits 8.
12-56-59-224| [ gm] [ 5.981439] Mode 327: 1600x1200 (8:8:8) linelength 6400 bits 32.
12-56-59-224| [ gm] [ 5.982400] Mode 328: 1152x864 (256 color palette) linelength 1152 bits 8.
12-56-59-224| [ gm] [ 5.983352] Mode 329: 1152x864 (5:5:5) linelength 2304 bits 15.
12-56-59-224| [ gm] [ 5.984326] Mode 330: 1152x864 (5:6:5) linelength 2304 bits 16.
12-56-59-224| [ gm] [ 5.985310] Mode 331: 1152x864 (8:8:8) linelength 3456 bits 24.
12-56-59-224| [ gm] [ 5.986306] Mode 332: 1152x864 (8:8:8) linelength 4608 bits 32.
12-56-59-224| [ gm] [ 5.986917] Linear framebuffer.
12-56-59-224| [ gm] [ 5.987845] mmap () return 0xb74e5000. Touch video memory.
12-56-59-224| [ gm] [ 5.987866] Ok.
12-56-59-224| [ gm] [ 5.987881] MTRRIOC_ADD_ENTRY falied, return -1.
12-56-59-224| [ gm] [ 5.991538] Use /usr/lib/ui32.so.
12-56-59-224| [ gm] [ 5.994885] WMEMCOPY: 28800K copied in 0.002342 sec.
12-56-59-224| [ gm] [ 5.996019] libc: 28800K copied in 0.001059 sec.
12-56-59-224| [ gm] [ 5.996700] movs: 28800K copied in 0.000602 sec.
12-56-59-224| [ gm] [ 5.997837] MMX: 28800K copied in 0.001013 sec.
12-56-59-224| [ gm] [ 5.998535] SSE2: 28800K copied in 0.000623 sec.
12-56-59-224| [ gm] [ 5.998580] Choose movs memcpy.
12-56-59-224| [ gm] [ 6.000021] Run '/sbin/resolver 0xc5de60 dns [10.36.64.11]', log '', env '', pid ''.
12-56-59-224| [ pfac] [ 6.000090] Run /sbin/resolver 0xc5de60 dns [10.36.64.11].
12-56-59-224| [ pfac] [ 6.000097] Ok, PID 692.
12-56-59-224| [ gm] [ 6.000114] Nobody can control terminal by VNC.
12-56-59-224| [ gm] [ 6.000124] Nobody can control terminal by WTRC.
12-56-59-224| [ gm] [ 6.001537] 10.36.64.11 => 10.36.64.11.
12-56-59-224| [ gm] [ 6.001667] Free ram before fork terminal client /sbin/rdpclient-SSE (session 1): 999044 Kb.
12-56-59-224| [ gm] [ 6.001801] Run '/sbin/rdpclient-SSE 1', log '/tmp/rdpclient.out', env '', pid ''.
12-56-59-224| [ pfac] [ 6.001938] Run /sbin/rdpclient-SSE 1.
12-56-59-224| [ pfac] [ 6.001960] Ok, PID 693.
12-56-59-224| [ pfac] [ 6.002036] Process pid 692 terminated, status 00000000.
12-56-59-224| [ rdpclient 693] [ 6.003311] RDP Terminal Client, WTware 6.0.72, pipe 1, pid 693.
12-56-59-224| [ rdpclient 693] [ 6.003377] Use /usr/lib/ui32-SSE.so.
12-56-59-224| [ rdpclient 693] [ 6.003752] Make RDP session with 10.36.64.11, port 3389.
12-56-59-224| [ rdpclient 693] [ 6.003764] No username.
12-56-59-224| [ rdpclient 693] [ 6.003773] No password.
12-56-59-224| [ rdpclient 693] [ 6.003781] No PIN.
12-56-59-224| [ rdpclient 693] [ 6.003790] No domain.
12-56-59-224| [ rdpclient 693] [ 6.003798] No shell.
12-56-59-224| [ rdpclient 693] [ 6.003806] No directory.
12-56-59-224| [ rdpclient 693] [ 6.003815] Window: 960x768@32.
12-56-59-224| [ rdpclient 693] [ 6.003823] PFlags 0x0000002F.
12-56-59-224| [ rdpclient 693] [ 6.003832] Keyboard 00000409:00000000.
12-56-59-224| [ rdpclient 693] [ 6.003840] My hostname "wtw080027240E28".
12-56-59-224| [ rdpclient 693] [ 6.003849] TCP: connecting to 10.36.64.11:3389.
12-56-59-224| [ rdpclient 693] [ 6.005102] TCP: connection with 10.36.64.11:3389 established.
12-56-59-224| [ rdpclient 693] [ 6.005116] Turn keepalive on.
12-56-59-224| [ rdpclient 693] [ 6.005222] Free ram after buffers allocation: 998164 KB.
12-56-59-224| [ rdpclient 693] [ 19.381328] Reconnect with NLA enabled.
12-56-59-224| [ rdpclient 693] [ 19.381397] TCP: reconnecting to 10.36.64.11:3389.
12-56-59-224| [ rdpclient 693] [ 19.382185] TCP: connection with 10.36.64.11:3389 established.
12-56-59-224| [ rdpclient 693] [ 19.382203] Turn keepalive on.
12-56-59-224| [ rdpclient 693] [ 19.391606] Server supports GFX Pipeline.
12-56-59-224| [ rdpclient 693] [ 19.391632] NLA EX.
12-56-59-224| [ rdpclient 693] [ 19.391648] SSL/TLS.
12-56-59-224| [ rdpclient 693] [ 19.412470] The user has permission to access the server.
12-56-59-224| [ rdpclient 693] [ 19.414517] RDP 10.6 server.
12-56-59-224| [ rdpclient 693] [ 19.418407] Enable font smoothing and Desktop Composition.
12-56-59-224| [ rdpclient 693] [ 19.421079] RDP5 encryption (X.509).
12-56-59-224| [ rdpclient 693] [ 19.671919] Advertice h264 AVC444.
12-56-59-224| [ rdpclient 693] [ 19.673905] GFX decoder thread.
12-56-59-224| [ rdpclient 693] [ 19.680183] Graphics output buffer 960x768, 1 monitors.
12-56-59-224| [ rdpclient 693] [ 19.680211] Monitor 0: 0.0-959.767 primary.
12-56-59-224| [ rdpclient 693] [ 20.365167] LOGON_EX_LOGONERRORS: ErrorNotificationType 0xfffffffe, ErrorNotificationData 0x0000000b.
12-56-59-224| [ rdpclient 693] [ 20.417687] Run 1 tile threads.
12-56-59-224| [ rdpclient 693] [ 22.964331] SessionId 0x0000000b: VRNZDRAV\kab16_2jan.
12-56-59-224| [ gm] [ 24.610665] [TOUCHSCREEN] ==================================================
12-56-59-224| [ gm] [ 24.610700] [TOUCHSCREEN] Hardware configuration:
12-56-59-224| [ gm] [ 24.610719] [TOUCHSCREEN] touchscreen = 0..32767,0..32767
12-56-59-224| [ gm] [ 24.610735] [TOUCHSCREEN] ==================================================
12-56-59-224| [ rdpclient 693] [ 68.553588] errorInfo 0x0000000c.
12-56-59-224| [ rdpclient 693] [ 68.553620] ERRINFO_LOGOFF_BY_USER: The disconnection was initiated by the user logging off his or her session on the server.
12-56-59-224| [ rdpclient 693] [ 68.672331] Receive Disconnect Provider Ultimatum.
12-56-59-224| [ gm] [ 68.672394] TSClient (sessionId 1, pid 693) gracefully end.
12-56-59-224| [ gm] [ 68.673689] Run '/sbin/resolver 0xc5de60 dns [10.36.64.11]', log '', env '', pid ''.
12-56-59-224| [ pfac] [ 68.673746] Run /sbin/resolver 0xc5de60 dns [10.36.64.11].
12-56-59-224| [ pfac] [ 68.673754] Ok, PID 697.
12-56-59-224| [ pfac] [ 68.682800] Process pid 697 terminated, status 00000000.
12-56-59-224| [RDP] close kotopipe (n = 0, errno 38).
12-56-59-224| [ pfac] [ 68.682844] Process pid 693 terminated, status 00000009.
12-56-59-224| [ gm] [ 68.697320] 10.36.64.11 => 10.36.64.11.
12-56-59-224| [ gm] [ 68.697598] Free ram before fork terminal client /sbin/rdpclient-SSE (session 2): 998328 Kb.
12-56-59-224| [ gm] [ 68.697610] Run '/sbin/rdpclient-SSE 2', log '/tmp/rdpclient.out', env '', pid ''.
12-56-59-224| [ pfac] [ 68.697644] Run /sbin/rdpclient-SSE 2.
12-56-59-224| [ pfac] [ 68.697650] Ok, PID 698.
12-56-59-224| [ rdpclient 698] [ 68.698845] RDP Terminal Client, WTware 6.0.72, pipe 2, pid 698.
12-56-59-224| [ rdpclient 698] [ 68.698903] Use /usr/lib/ui32-SSE.so.
12-56-59-224| [ rdpclient 698] [ 68.699378] Make RDP session with 10.36.64.11, port 3389.
12-56-59-224| [ rdpclient 698] [ 68.699389] No username.
12-56-59-224| [ rdpclient 698] [ 68.699398] No password.
12-56-59-224| [ rdpclient 698] [ 68.699407] No PIN.
12-56-59-224| [ rdpclient 698] [ 68.699415] No domain.
12-56-59-224| [ rdpclient 698] [ 68.699423] No shell.
12-56-59-224| [ rdpclient 698] [ 68.699431] No directory.
12-56-59-224| [ rdpclient 698] [ 68.699439] Window: 960x768@32.
12-56-59-224| [ rdpclient 698] [ 68.699448] PFlags 0x0000002F.
12-56-59-224| [ rdpclient 698] [ 68.699457] Keyboard 00000409:00000000.
12-56-59-224| [ rdpclient 698] [ 68.699465] My hostname "wtw080027240E28".
12-56-59-224| [ rdpclient 698] [ 68.699474] TCP: connecting to 10.36.64.11:3389.
12-56-59-224| [ rdpclient 698] [ 68.700181] TCP: connection with 10.36.64.11:3389 established.
12-56-59-224| [ rdpclient 698] [ 68.700196] Turn keepalive on.
12-56-59-224| [ rdpclient 698] [ 68.700324] Free ram after buffers allocation: 997440 KB.
12-56-59-224| Connection from wtc.exe at 10.36.64.10.
Логи wtlb 1 сервер:
Логи wtlb 2 сервер:
Логи терминала:
